May 31, 2013, 17:47 |
Average Velocity
Michal
Rep Power: 13 |
I simulate a velocity distribution in an exhaust channel. After solve I check a velocity distribution (as contour) in an selected area. Is there a posibility to show one average value of velocity in this selected area? (for exampe Area1, d=200mm, v=+1,2 m/s) Michal |
June 1, 2013, 07:13 |
Rep Power: 143 |
Yes, I think you can put CEL expressions in a text object.
June 1, 2013, 08:22 |
rasool
Rep Power: 12 |
ave(velocity)@area
June 1, 2013, 09:37 |
Michal
Rep Power: 13 |
thank you for advices: In CFD-post I wrote an expression: ave(Velocity)@Area but I have an error: "The following unrecognised name was referenced: Area." Velocity and Area are under default variables in CFX. |
June 1, 2013, 11:04 |
Erik
Rep Power: 23 |
Rasool just wrote the word area to be general. Really put the name of that specific surface there.
ave(Velocity)@B1.122 or Outlet or something like that. |
June 2, 2013, 10:58 |
Rep Power: 14 |
The easiest way to do that is by using "Function Calculator" in CFD-Post (tab Calculators).
If you want to monitor this quantity during a CFD simulation, you will have to define the suggested CEL in CFX-Pre under "Output Control" (tab Monitor). |
June 3, 2013, 02:51 |
Lance
Rep Power: 22 |
Display Modes | |
Monitoring Volume Average of Liquid Velocity Magnitude in a Bubble Column / Airlift | kevinlipps | OpenFOAM Post-Processing | 4 | May 19, 2016 06:59 |
average velocity | kato | FLUENT | 0 | February 12, 2013 05:40 |
How to plot average velocity vs direction vector in fluent | hamidhamidhamidhamidhamid | FLUENT | 0 | January 1, 2013 15:13 |
Problem with time average tangential velocity in swirl flow. | lakhi | FLUENT | 5 | July 18, 2012 17:28 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
