July 24, 2013, 10:55 |
Water gas shift reaction source term in cfx
SETTAR
Rep Power: 13 |
i try to working about a steam methane reforming reaction into a channel with a catalytic wall and for the species eqation, i have a source term relative to water gas shift reaction, it's a volumetric source term. my question is how can i know the expression of this source term used by CFX 11 ? because i study wich i follow use the cfx but i don't know the expression for this term Help me please Thanks before |
July 25, 2013, 02:50 |
Rep Power: 143 |
Do you have a CFX model which you are trying to figure out how it works or are you trying to do a new simulation?
July 25, 2013, 07:43 |
SETTAR
Rep Power: 13 |
Hi ghorrocks thank you for your answer
in fact i haven't a CFX model, i try to do a new simulation by following some results generated by a CFX model, and in this article it is not mentionned the expression of the volumetric source term, when i contacted the author, he told me that he used the ANSYS expression for the water gas shift reaction source term. When i searched in the manual of the version 11 i didn't find this term i can give you the equations system if that is necessary Thanks before. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
source term reaction | wlt_1985 | FLUENT | 0 | July 28, 2011 13:56 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
