July 25, 2013, 09:30 |
furnace design using CFX
Dear all,
I try to design a batch furnace with a flat flame burner mounting on the roof. The dimension of the furnace is to be determined. The goal is to achieve 1500 degree Celsius on the floor while the vertical velocity near the floor is small. Is it appropriate to use ANSYS CFX as a tool for DESIGNING a furnace from scratch? Is there any combustion tutorial of CFX or fluent available? Thank you |
July 25, 2013, 21:04 |
Rep Power: 143 |
CFX can do this. I am not sure CFX is the best way to design a furnace but you can do it that way if you wish.
There are combustion tutorials provided with CFX. But if all you want is the temeprature at the bottom you probably do not need a combustion model and heat sources will do fine. |
design, furnace, parameter |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
[Other] CFX 11.0 / Ansys Workbench Design modeller - .geo file | Hectux | ANSYS Meshing & Geometry | 1 | April 7, 2009 05:04 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
CFX design modeler | Merkur | CFX | 0 | June 5, 2006 10:44 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
