July 26, 2013, 08:34 |
pressure value out of domain!
I'm simulating a weir in a channel. I want to read pressure in some specific points. I draw a line with "cut" option then I read pressure at the first point of the line but I noticed that there are some pressure values below this point out of the domain. How is it possible?! what's the problem?
July 27, 2013, 07:26 |
Rep Power: 143 |
The cut option is giving you a value at every point that curve cuts a control volume boundary face.
July 27, 2013, 16:22 |
July 28, 2013, 07:43 |
Rep Power: 143 |
It is interpolating from the control volume points to the locations you are specifying. The interpolation is not perfect and can result in locally strange results.
July 28, 2013, 10:41 |
Rep Power: 19 |
alternative is to create a contour on X, Y, Z, or theta on a plane or iso surface. If this gives a contour line where you are interested, create a polyline from this contour line and see if the problem remains.
or create a polyline from a boundary intersection. |
July 29, 2013, 03:30 |
thank you all.
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 06:29 |
Reduced domain/ Pressure inlet to velocity inlet | victoryv | FLUENT | 1 | June 29, 2013 14:45 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
