June 9, 2013, 09:46 |
SST turbulence with Gamma theta
Govindaraju
Rep Power: 17 |
Dear friends
How to model laminar - turbulent - laminar flow? . Can I use SST with gamma theta model (default)? Thank you |
June 9, 2013, 22:40 |
Govindaraju
Rep Power: 17 |
Thank you for your kind reply.
My simulations has been finished .But at the end of the simulation , I found the following error message. Is this error message important? +--------------------------------------------------------------------+ | ERROR #002100004 has occurred in subroutine Out_Scales_Flu. | | Message: | | The Reynolds number is outside of the range expected based on the | | Option selected for the TURBULENCE MODEL. Check this setting, | | the values of the properties, mesh scale, consistency of units | | and solution values in the input file. Execution will proceed. | +--------------------------------------------------------------------+ Thank you Regards Govind |
June 10, 2013, 02:28 |
Lance
Rep Power: 22 |
No, its only a warning. A forum search would have told you that.
See e.g. this post which came up when I searched for your error message: http://www.cfd-online.com/Forums/cfx...tml#post431551 |
June 10, 2013, 10:13 |
Govindaraju
Rep Power: 17 |
Thank you Mr Lance
June 18, 2013, 11:34 |
Govindaraju
Rep Power: 17 |
Dear all
For low Re turbulence problem for the first case, I use SST turbulence and not selecting gamma theta option then for the same boundary condition problem , I select SST turbulence and selecting Gamma theta option. I got two different answers Please guide me. Thank you |
June 19, 2013, 09:14 |
Govindaraju
Rep Power: 17 |
December 29, 2013, 22:03 |
#9 | |
Hope this sheds some light on the issue. |
Display Modes | |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Porous artery and SST turbulence model | kmgraju | CFX | 13 | June 11, 2013 00:50 |
K - epsilon VS SST turbulence model | Maicol | Main CFD Forum | 0 | November 30, 2012 16:25 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
