Error Message when running solver
When i load my file into the solver i get the following error message. I searched for the subrountine 'CAL_TAUWALL' and i do not get any results regarding it on cfd online or the manuals.
A copy of the error message is below. I know it is something to do with the case setup, but i cant figure out what precisely. Error in subroutine CAL_TAUWALL : LOCALE : physical type is : INLET GETVAR originally called by subroutine Write_Cgns_SbpVx +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine GV_ERROR | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ |
I got the same problem now.could you explain it a little bit more in detail? What did ;solution output methods' here mean? Thank you very much.:) |
The error indicates to me that you are trying to output a wall shear stress on an inlet boundary... wall shear stress values will only be available on wall boundaries. Should run fine if you turn this output off.
