Post-process Isosurface Setting Anomalies
Old   June 18, 2013, 07:52
Post Post-process Isosurface Setting Anomalies
Manav Gunesh
AeroJay is on a distinguished road
Dear All,
I ran a multiphase simulation in a closed domain discretizing a tunnel. I wanted to display the free surface of the primary fluid which is water during the run therefore resorted to isosurface in the post process results. My only concern with the latter is the fact that:
* when i set the volume fraction of water to 0.5 as recommended i get patches of unfilled space in the domain.
* when i do decrease the water volume fraction i get a better result as the flow covering of the domain.
Your help is very much appreciated friends. If you could shed some light on the matter and kindly advise a better solution.
Thanks,
AeroJay
AeroJay is offline   Reply With Quote
Old   June 19, 2013, 19:14
Can you post images of what you are seeing? Also post the CCL file.
Old   June 20, 2013, 02:44
Post Isosurface details
Manav Gunesh
Dear Ghorrocks,
[I]Please find the comparative figures denoting the value of 0.05 and 0.5 for the post-processed displays. Also find the CCL file attached.
Thanks,
AeroJay
CCL.txt
Old   September 5, 2013, 03:16
Daan de Boer
daandb is on a distinguished road
I have a similar problem with a sloshin study, there are gaps in iso-surface near the baffle plates. Hope someone knows a solution.
daandb is offline   Reply With Quote
Old   September 5, 2013, 05:17
hmasenger's Avatar
hamed
hmasenger is on a distinguished road
is that some kind of chute or spillway?did you calculate the water table in the slop by open channel hydraulic equations? did you use a proper mesh grid on the slop which could express the water table ?it can be concluded by the pic you attached that there is no value for water volume fraction=0.5 and on the slop there is a very thin layer of water caused by high frude number.. i think a higher mesh quality would help.pleas let me know if it solves the problem i am working on some kind of similar model
hmasenger is offline   Reply With Quote
Old   September 5, 2013, 08:13
I think Hamed is on the right track - a finer mesh will probably resolve this.
isosurface, multiphase, volume fraction
contours display in post process askriitr FLUENT 0 July 1, 2009 10:55
cfx post process help musman CFX 3 May 19, 2009 05:01
post process to get an arbitrary face data oniboy Siemens 2 February 28, 2008 22:12
how to post process with visual3 dell Siemens 2 December 17, 2002 01:59
200 data files to post process (how?) Mark R FLUENT 1 August 9, 2001 13:35
