June 22, 2014, 16:15 |
FSI Simulation of a 2D airfoil
Rep Power: 11 |
Hi everyone,
I am doing a FSI simulation using CFX and the Structural solver from ANSYS. The problem is a 2D airfoil, leading and trailing edges are solids (structural steel) and the covering is a flexible membrane. It is a steady-state analysis. I first tried doing a 1-way FSI analysis, just to check. I applied the pressure obtained in CFX to the Structural system, and it worked without problem. But when I am trying to do the 2-way FSI, ANSYS solves the first Load Step Number, then the Solver for CFX runs smoothly, reaching the maximum iterations allowed (not important to reach the exact solution, as the body will change on the next iteration). Forces are transferred to the ANSYS solver, but after the second equilibrium iteration comes the error message: "Excessive distortion of Element 938" (or another element number) When trying the simulation with greater stiffness, this problem does not appear, so we guess that the overall setup is quite good. The mesh was created using ICEM over a CATIA file, which already contained the airfoil and the fluid domain. The size of the first element of the mesh on the boundary layer is 0.05mm (to ensure y+<1). The maximum deformation expected on the airfoil (according to the 1-way FSI) should be of the order of 1mm. Any idea about where the origin of the problem could be? If more info is needed, just ask. Thank you! |
June 23, 2014, 09:53 |
Rep Power: 21 |
The forces that the structural solver receives and printed in its solver output. How do these forces compare between the first and second coupling iterations?
June 23, 2014, 11:51 |
#3 | |
Rep Power: 11 |
Thanks for your answer.
WhatTotal Force varDim, nnodes, nload 3 108 324 Values: Total Force -0.31395E-05 -0.22425E-03 -0.14624E-07 -0.11629E-04 -0.19598E-03 -0.25533E-07 -0.31353E-05 -0.22427E-03 -0.14625E-07 -0.11625E-04 -0.19597E-03 -0.25532E-07 0.15230E-05 -0.21638E-03 -0.52852E-08 0.15259E-05 -0.21639E-03 -0.52853E-08 0.18759E-05 -0.18495E-03 -0.29302E-08 0.18774E-05 -0.18495E-03 -0.29301E-08 0.15525E-05 -0.14565E-03 -0.22231E-08 0.15538E-05 -0.14565E-03 -0.22231E-08 (...) I set a under relaxation factor of 0.75, but I have also tried reducing it with no success. |
June 24, 2014, 11:13 |
Rep Power: 21 |
So if there's no forces in the first coupling iteration then I assume you haven't used a steady-state CFX solution as a starting point. You should solve CFX first, then link the Solution cells so that the steady-state CFX results initialize the transient case.
Regarding the forces, it would be better to look at the total x,y,z forces received by the structural solver. You don't need debug output to see these forces. You should also add monitor point in CFX for the force on the membrane (force()@membrane) and the max total mesh displacement (maxVal(Total Mesh Displacement)@membrane). Check to see if the monitors are oscillating or if they are stable. |
June 25, 2014, 07:43 |
#5 | |
Rep Power: 11 |
If I try changing the order of the solvers, so that CFX solves first, then at the first iteration for the mechanical solver it has the forces transferred, which should correspond to the ones for a steady-state with no coupling. However in this case I also have the error with the excessive distorsion. |
June 25, 2014, 10:11 |
Rep Power: 21 |
As long as the forces that CFX sends are reasonable, then your approach is OK. CFX may not have fully converged, so the forces may not be reasonable. You don't need to fully converge CFX, but you should still check the total x,y,z forces received by MAPDL (they are printed in the ANSYS.stdout file for each coupling iteration).
If the forces look reasonable but MAPDL still fails then check the structural side by running without FSI. You said you already did that by mapping pressure from CFX. When you do this make sure you are making a fair comparison. For example, in the FSI case you might be using a single substep per coupling iteration. So when mapping pressure you should also solve using a single substep (i.e. no load ramping). |
June 27, 2014, 03:08 |
#7 | |
Rep Power: 11 |
3D CONTACT ELEMENTS: 152 CONTACT POINTS HAVE TOO MUCH PENETRATION The number of points reduces, and after iteration 10 this message does not appear anymore. I do not know if it could be affecting the problem. I also got the following warning messages: One or more contact pairs are detected with a friction value greater than 0.2. If convergence problems arise, switching to an unsymmetric Newton Raphson option may aid in convergence. Large deformation effects are active which may have invalidated some of your applied supports such as displacement, cylindrical, frictionless, or compression only. Refer to Troubleshooting in the Help System for more details. One or more contact regions may not be in initial contact. Check results carefully. Refer to Troubleshooting in the Help System for more details. I have quite little experience with the structural component and I can not say how that may be affecting the coupling solver, and what could be done to avoid that. Thank you very much for your help. |
June 27, 2014, 12:02 |
Rep Power: 21 |
You might be hitting a different problem here. Does the coupled FSI run always work in the first coupling iteration, even when non-zero forces are passed? You'll need to provide CFX initial value or switch the solve order so CFX goes first to test this. If you can show that it works OK in the first coupling iteration but fails in the second coupling iteration when similar forces are received by MAPDL then you've likely hit a 2-way FSI limitation. Certain contact element types are known not to work with 2-way FSI. There's usually a work-around. If you do see the above behaviour then can you summarized the constraints and contacts used in your structural model (Fixed Supports, Remote Displacements, Contacts, Springs, etc)?
June 30, 2014, 02:28 |
#9 | ||
Rep Power: 11 |
The lateral surfaces of the trailing and the leading edges are set as fixed support. Then, as we are doing a 2D case, the displacement of the membrane is set to 0 in the z direction. We also set the edge of the membrane over the leading edge as fixed support, because if not we had some troubles solving the 1-way. And finally the membrane is defined as fluid-solid-interface. We want that the membrane deformes, but by fixing it on both trailing and leading edges I think that we are preventing it to transfer the tensions between the upper and the lower surfaces, aren't we? Maybe the connections and boundary conditions could be changed, so that they also match the desired behaviour. |
June 30, 2014, 09:14 |
#10 |
Rep Power: 21 |
The frictional contact is likely the problem. Just as a test, make this a bonded contact and see if it runs. If that works, can you post a screen shot of the frictional contact settings?
June 30, 2014, 11:56 |
#11 | |
Rep Power: 11 |
The original idea about the contacts and connections is that the membrane is joined to the structure at some point (e.g. on the trailing edge) and that the rest slides over the other surface, so the deformation between the upper and the lower part influence themselves and they transmit the tensions. But I do not know how that could be set up, or if it would be possible or not. And does it make a difference, if the membrane is bonded to the solid by an edge or using a little surface? |
June 30, 2014, 15:47 |
#12 |
Rep Power: 21 |
You'll have to do some trial and error here. The problem is that some element types/options are not compatible with FSI. Different contact element types/options will be created depending on your constraints and contact settings. Fixed supports certainly work OK. Bonded surface-to-surface contact works OK in my experience.
Frictional contact I'm not so sure about. Edge-to-surface contact I'm not sure about either. The symptom to look for is everything works fine in the first coupling iteration, but fails in the second coupling iteration. Of course things can fail in the second coupling iteration because of other reasons, but if the forces didn't change then it likely you've hit this limitation. Try to make the constraints/contacts on your structural model as simple as possible and get something to works for 2 coupling iterations. Once you have this start adding the contacts back one by one until you find which one is causing the problem. |
July 1, 2014, 11:42 |
#13 |
Rep Power: 11 |
I have been trying with all combinations I could think of. The only way it is working is when I bond the surface over the trailing edges and half over the leading edge, which really limits the movement of the membrane. The rest of the membrane is set with a frictional connection, as the frictionless was also giving trouble.
Can you think of a way to set the geometry connections, so it is closer to the desired behavior? I tried for example bonding only over the trailing edge, so the membrane could "slide" over the leading edge, to adapt better, and it worked fine on the 1-way simulation. |
July 3, 2014, 09:23 |
#14 |
Rep Power: 21 |
I'm still not 100% sure if you are hitting this problem with certain contact elements not working with FSI. One way you might be able to confirm this is to use the frictional contacts but make the membrane material much stiffer (say a factor of 100 or 1000). If you are hitting a code limitation then it should still fail with the stiffer membrane. If it really is a "standard" element distortion error then it should not occur with a stiffer membrane.
Frictional contact should be compatible with 2-way FSI if you set "Formulation = Beam (Beta)". You'll need beta feature enabled (from Workbench go to "Tools > Options > Appearance"). |
airfoil2d, ansys 14.5, cfx, fsi 2-way coupling |
Comparison the airfoil 0012 experimental result and simulation result | harrislcy | FLUENT | 30 | August 29, 2013 10:27 |
Rigid body motion error when restarting a terminated FSI simulation | lingdeer | ANSYS | 1 | May 19, 2013 01:40 |
Airfoil simulation with k-epsilon realizable, calculation of transition possible? | level | FLUENT | 6 | January 15, 2012 12:32 |
2 way FSI simulation errors | ninjabro | CFX | 1 | September 8, 2011 08:23 |
NO STAGNATION POINT FOR AIRFOIL SIMULATION | Rif | Main CFD Forum | 6 | February 4, 2008 07:33 |
