floating point error when supersonic inlet is used |
October 29, 2022, 02:34 |
Zese
Rep Power: 12 |
Dear all
I want to simulate a compressible flow passing a blade of turbine in 2D. I chose Ideal gas air as the fluid. the inlet velocity is 1421 m/s with 17.23 degree and total pressure 1.3 Mpa. the geometry and BC are shown in the pic. when I put supersonic as the flow regime of inlet, after 10 iterations it failed because of fail in P-MASS equation. when the I choose lower velocity with subsonic or mix flow regime the equations are solved perfectly. because it is the first time I am simulating the compressible flow, I dont know what I can do to solve it. Best regards |
October 29, 2022, 13:57 |
Rep Power: 32 |
From the snapshot, it seems you are using symmetry planes (2D representation), translational periodicity top and bottom, and "an opening" at the exit from the arrows.
Is that correct? Openings are subsonic, are they not? What about using a supersonic outlet as well?
October 31, 2022, 00:16 |
#3 | |
Zese
Rep Power: 12 |
Thanks for your response. yes it is correct. I did what you said and the same happened. the pic I attached shows the massage of CFX. I dont know what else I can do |
October 31, 2022, 03:51 |
Rep Power: 143 |
There is an FAQ on this: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
I recommend you read it as it has the general advice for this situation.
October 31, 2022, 07:15 |
#5 | |
Rep Power: 32 |
0 - Read Glenn's suggestion, then 1 - Subsonic flow 2 - Initial guess? is it reasonable? or just a wild guess? Suggestion: assume constant total pressure/total temperature throughout, then you are only guessing the velocity field. 3 - You have not specified what timestep was selected. 4 - Have you read the documentation to understand the feedback in the output file? That is, what do all those numbers for the different equations mean?
Understanding The Floating Point Exception Error Message | RussellHolt | OpenFOAM Running, Solving & CFD | 2 | August 6, 2022 00:00 |
Floating point exception error when rotate the geometry | zyfsoton | OpenFOAM Running, Solving & CFD | 1 | June 20, 2022 05:49 |
Floating point Exception error in fluent | Nima Shah | Fluent Multiphase | 2 | April 29, 2022 10:20 |
[foam-extend.org] foam-extend 3.2 on Ubuntu 12.04, Floating point exception for tutorials | arsalan.dryi | OpenFOAM Installation | 7 | November 14, 2016 17:33 |
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong | jannnesss | CFX | 5 | February 25, 2011 16:24 |
