adaptive variable range in post
Old   September 25, 2013, 05:17
Default adaptive variable range in post
keeper is on a distinguished road
Hello all.
I have a question about variable range in CFX Post. I simulate wide range of designs and the goal is to decrease temperature in the system. In my cst I have lots of contours of temperature field on solids. Is there any easy way how to decrease all ranges on all contours by doing few operations instead of redefining ranges for every single contour?
Thank you for help.
Best Regards
keeper is offline   Reply With Quote
Old   September 25, 2013, 05:35
Lance
Lance is on a distinguished road
Maybe this would work?
Group all the planes into a Surface group, then under the color tab, chose temperature and the range you want. Or create a contour using only the surface group as location.
Lance is offline   Reply With Quote
Old   September 25, 2013, 05:46
Thank you for reply. My cst contains lots of contours and as a location I choose different domains and different surface locations on them. So I need to have all of them separately in a single object, just to move with range of each contour.
Old   September 25, 2013, 07:14
Use a session file to change all the ranges in one go, or define them as parameters and change them from workbench.
Old   September 25, 2013, 12:40
Edmund Singer P.E.
singer1812 is on a distinguished road
Setup the contours to use an expression for min and max? Just change the expression?
singer1812 is offline   Reply With Quote
Old   September 26, 2013, 02:33
thank you for all replies. Setting ranges as a parameter seems to be the best solution. thank you again
New Variable in CFX Post Ben CFX 9 June 20, 2012 18:10
Condensation as an additional variable Clark Griswold CFX 2 April 21, 2012 07:20
Assign new variable in CFX Post Ben CFX 1 August 25, 2008 14:59
Variable for Number of Mesh Elements CFX Post Matt CFX 0 August 14, 2008 17:05
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
