September 25, 2013, 04:58 |
Simulation in CFX about CRF
Ch
Rep Power: 13 |
Dear friends,
I have a very robust design of a contra-rotating fan, now I need to validate this design and find the problems. However, after i generated the mesh in turbogrid and set up all the parameters in pre-CFX, I always got the problem "floating point exception: overflow". I did a lot of changes, such as improving the mesh, adding the good initial conditions, decreasing the timestep and changing the turbulence model to SST. However, I still can not get proper convergent results. Can anybody help me to check the case? Here I can not attach the .def and .cfx files since it is too large. If there is sombody who can help me, I will send you those files by email. Thanks very much! |
September 25, 2013, 07:19 |
Rep Power: 143 |
Do not post the def or cfx files, they are too large and nobody has time to look at them anyway.
Please post an image of what you are modelling, and image which shows the mesh in key parts of the simulation, and attach your CCL (not the whole output file). |
September 26, 2013, 22:26 |
CZL
Rep Power: 12 |
We are in the same boat.
Blast simulation with ANSYS CFX or FLOW-3D etc. | xji | ANSYS | 0 | November 30, 2012 16:57 |
CFX vs FLUENT for particle tracking simulation | iman | ANSYS | 2 | August 31, 2012 20:34 |
nucleate boiling simulation in CFX | Anil | CFX | 3 | August 25, 2010 14:18 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 08:44 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 13:54 |
