Problem with rotating impeller in centrifugal pump |
October 4, 2013, 02:49 |
Rep Power: 12 |
I have work with Ansys but not too much with CFX. I am having a problem with a centrifugal pump. I think my problem is due to the boundary conditions or perhaps the interface, I am not sure. I have check the rest of the thread but I couldn't find an answer and the tutorial is only for an impeller, not for a complete pump. I describe my set up in the enclosed file. All advise is grateful Last edited by Kalybre; October 4, 2013 at 07:31. |
October 4, 2013, 06:06 |
Rep Power: 143 |
The document is not readable. Please do not post it on links, just post it on the forum.
October 4, 2013, 08:07 |
anonymous
From my point of view there are two errors:
- For the impeller define the rotation as "Domain motion: rotating" and not as "Rotating Wall" - Domain Interface: Interface Model-Frame Change/Mixing Model: here you have to use either Stage or Frozen Rotor otherwise this can not work. |
October 4, 2013, 08:41 |
#4 | |
Rep Power: 12 |
- No slip wall (this is the only that allow add rotary velocity) - Free slip wall - Specific shear Perhaps I should define the DEFAULT DOMAIN rotating? |
October 4, 2013, 08:56 |
anonymous
I don't understand what your default domain is!
You should define different domains for each component (impeller, volute, inlet pipe) and then define the stationary domains as stationary (volute and inlet pipe) and the rotating domain (runner) as rotating with your RPM set and the no slip wall condition for hub, shroud and blades. If you do this right the default domain will disappear as it normal contains only parts that have not defined in another domain. |
October 8, 2013, 05:32 |
#6 | |
Rep Power: 12 |
Now I have defined 3 different domains: 2 stationary and one rotating (impeller). The Domain interface: Frame Change/Mixing Model : Frozen Rotor ( y tried with stage too), between : Inlet pipe - impeller & impeller - Casing. With these should work, but I have obtained the results on the enclosed picture. Why the impeller is stationary? I can't understand it. |
October 8, 2013, 05:44 |
Rep Power: 143 |
Have you read the documentation about rotating frames of reference? There are many different ways of doing this - you need to understand the assumptions behind the models to understand the results.
July 26, 2014, 17:42 |
Bilal Waseem
Rep Power: 12 |
I am having similar issues.
When I use frozen rotor interface, CFX asks for pitch setting as well. My inlet pipe side of interface has a different mesh than the mesh on impeller side of interface. Does that have an adverse effect ?? |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 06:42 |
Having a few problems in simulating a rotating impeller | ajinsan | CFX | 12 | February 4, 2016 16:10 |
How to Create the Rotating Reference Frame of a MRF Problem in DM wrt to an Interface | Zev Xavier | FLUENT | 11 | October 14, 2014 08:46 |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 08:53 |
Pump Impeller | aboazm | ANSYS | 0 | November 2, 2012 16:51 |
