June 16, 2018, 07:24 |
variable properties implementation
mike
Rep Power: 14 |
Dear All
I am going to consider variable fluid properties as a function of temperature and pressure as a real gas model. These properties are defined as a polynomials at certain temperature and pressure and must be interpolated at any temperature and pressure of flow domain. I am really confused how to do this in Ansys CFX. Any help or advice is appreciated. Sincerely |
June 17, 2018, 07:03 |
Rep Power: 143 |
Please describe the polynomials and interpolation you intend to use.
Also - make sure you have done the CFX tutorial examples so you know how to use CEL expressions, as it is probably going to use CEL expressions.
June 21, 2018, 08:22 |
mike
Rep Power: 14 |
Hi Glenn
Thanks for your reply. Following your suggestion, I studied for CEL expressions and tutorials. By the way, I am going to evaluate CFX capability for a high velocity flow over a sphere in order to get true wall heat flux. The considered Mach is 10. I have imported compressibility factor and specific heat flux and transport properties as a table which are a function of temperature and pressure. So in order to import the table as 3D, the third independent variable is set to an optional constant (e.g. 0). A pure material is user defined with a density defined as expression including compressibility factor. Cp and transport properties are as CEL expressions, too. I have defined a velocity expression in order to increase farfield slowly and step by step. I have some questions: - Is it necessary to set reference state parameters? - What about table generation? I have set min and max values of T & Pabs such that flow field corresponding values are within this range. - What about error tolerance? Default 1e-2 value causes problem. Increasing it to 0.5 yields in better convergence up to Mach=7, but higher Mach number fails the simulation. How high can this error tolerance be? In out file the following message are printed: User Defined Monitor Information | +--------------------------------------------------------------------+ Monitor Point: Monitor Point 1 +--------------------------------------------------------------------+ | ****** Notice ****** | | | | Adaptive table generation failed for the material property: | | | | Static Enthalpy | | | | This may have occurred because the equation of state or specific | | heat capacity function contains regions with large derivatives | | or because the error tolerance is too small. Execution will | | continue with a uniform distribution using 100 points in | | each coordinate direction. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | | | Adaptive table generation failed for the material property: | | | | Static Entropy | | | | This may have occurred because the equation of state or specific | | heat capacity function contains regions with large derivatives | | or because the error tolerance is too small. Execution will | | continue with a uniform distribution using 100 points in | | each coordinate direction. What should I do? I am a fan of CFX. I want to implement such flow conditions in CFX. That's your kind if you can help me. Sincerely, Mike |
June 21, 2018, 15:48 |
Rep Power: 32 |
Would you mind describing which material properties you are providing?
In particular, thermodynamic properties, say Density, Specific Heat, else? What kind of variation are you accounting for? T only? T and P? T and P variations are tricky and not arbitrary (see the documentation for details) |
June 22, 2018, 03:40 |
mike
Rep Power: 14 |
Hi my friend.
Density, specific heat, momentum and energy transport coefficients which have been considered as a function of both T and P. |
June 22, 2018, 11:08 |
Gert-Jan
Rep Power: 27 |
I doubt if CFX is suitable up to Mach =10. Did you check support on this?
June 22, 2018, 19:31 |
Rep Power: 143 |
Most gasses have significant dissociation at Mach 5. You are double that speed. CFX does not have a plasma model so I don't think CFX is a suitable code for this. Are you sure CFX is going to be able to handle your application?
June 23, 2018, 02:42 |
#8 | |
mike
Rep Power: 14 |
Yes, I know about dissociation and all about real gas behavior of air in high temperature. I have progressed a bit and now my question is how to have both specific heat and static enthalpy as functions of both T and P in Cfx. I have studied some about RGP format in CFX but as I see there we should define critical pressure and temperature. Is there any way to define both cp and h variable? Sincerely |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Setting variable material properties | bigphil | OpenFOAM | 0 | June 11, 2009 07:01 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 08:19 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Multi_component Vs Additional Variable | Anurag | CFX | 2 | February 4, 2005 16:45 |
