CFX Reduce transient output file size
Old   October 10, 2013, 02:51
Default CFX Reduce transient output file size
ThomasN is on a distinguished road
Hello to everybody,
first: it's a great Forum, many thanks for the helpful advices!
I've a question concerning the CFX transient output files. On transient calculations and with the default settings the files become bigger over the time because every file saves the whole convergence history.
For example I start with my 2D model with a file size of 40MB and after 500 transient files it's 200MB.
Is it possible to switch that off? I only want to save my results.
Thanks
Thomas
ThomasN is offline   Reply With Quote
Old   October 10, 2013, 05:05
You must be saving full results files. Make the transient results selected variables only and they will be much smaller - but you should save a full one every now and again to restart from if the run crashes.
Old   October 10, 2013, 05:27
Oh, OK, that makes sense. If I select "selected variables" I can't restart from these Points right?
Another question: If my run crashes and I restart my calculation with the last transient file the solver produces a new Folder for the following result files. Is there a way to connect the files of the different folders in CFX Post?
Old   October 10, 2013, 05:34
That's right, unless you add enough variables such that it can restart from it.
If you are recovering from a crashed run you are going to have to do the post processing in two sections (if you are doing things in time).
Old   October 10, 2013, 05:37
OK many thanks for your reply!
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Reduce output file size!! Jonac CFX 1 September 15, 2000 03:24
