Trying to get def file - but Solve greyed out |
November 6, 2013, 13:15 |
Anon
Rep Power: 12 |
I'm trying to create the def file to send to someone else, but when I go to Tools>Solve in CFX-pre, it is greyed out. Why is this?
November 6, 2013, 15:23 |
Anon
Rep Power: 12 |
I got the def file through execution control, but Solve is still greyed out. Hmm.
November 7, 2013, 04:26 |
Rep Power: 15 |
do you work in WB or in standalone? If you do so in WB there is no option like that. You have to double click on Solution in CFX box (in WB scheme) and it creates your desired def file. Then you can simply find it in project folder (Project/dp0/CFX/CFX/CFX.def)
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 14:22 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
