Reference diameter
Old   December 3, 2013, 08:05
Default Reference diameter
Arslan
ArslanOZCAN is on a distinguished road
Hi;
In CFD-Post i am doing a Hydraulic Francis turbine analysis. Everything seems ok except the parameters in result report. The reference diameter is bigger than runner outlet diameter and torque value is higher than expected. Efficiency is also lower than expected. How i can set reference diameter manually and which formulas does CFD_Post uses to calculate result parameters. I couldn't find in tutorial files.
I have checked all the contours, streamlines and blade angles, everything seems normal.
Regards.
ArslanOZCAN is offline   Reply With Quote
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
