December 3, 2013, 10:06 |
FSI error detected by routine PSHDIR
behne
Rep Power: 14 |
Hi all,
I´m doing a 2-way FSI with Ansys CFX and mechanical. Can you help me with this error? It appears while starting the first iteration with CFX. Details of error:- ---------------- Error detected by routine PSHDIR CDRNAM = /FLOW/GETVAR/BNCN_DIR/BCP1 /NOVARIABLES CRESLT = NONE Current Directory : /FLOW/SOLUTION/TSTEP0/CLOOP0/ZN1/BELG15/IP Thanks! |
December 3, 2013, 14:15 |
Rep Power: 32 |
The ANSYS CFX solver is trying to find the information for the non-overlap section of a domain interface. Check that the boundaries on either side of your domain interfaces have the correct Non-Overlap Boundary Conditions settings.
If the situation continues, you should contact ANSYS support |
bcp1, cdrnam, fsi, pshdir |
Difference between Junction BOX routine & CEL expression in a 1 way FSI | vmlxb6 | CFX | 1 | March 1, 2011 08:50 |
fsi | sun | Siemens | 8 | January 19, 2009 23:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
