Please**need help on Tow phase flow ( water & steam water) analysis** |
December 19, 2013, 02:42 |
ali
Rep Power: 12 |
Dear friends
i want to model a cylindrical porous domain which has inlet at the bottom and outlet at top. porous has heat generation which make some water to become vapor. i modeled it as follow: 1- I defined one continuous fluid as water and one dispersed fluid as water steam ( bubble size 0.002 m) with IPWS F97 mat properties. 2- use of mixture model without free surface model 3- thermal energy 4- particle model 5- thermal phase change with saturation temperature 6- two resistance , zero resistance and ranze marshal models have been implemented. i try to run this problem for 1.014 bar domain pressure with 100 C saturation temperature which was successfuland two phase flow is performed. MY PROBLEM : BUT when i want to run it for higher pressure like 55 bar with 270 C saturation temperature, water don't become two phase and water temperature increases more than saturation temperature without phase change. what should i do please help me. |
December 19, 2013, 03:24 |
hi
ali
Rep Power: 12 |
is there any body to help me
December 19, 2013, 16:15 |
Rep Power: 143 |
Have you covered the basics? http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
cfx, evaporation, multi phase, water steam |
Mass Flow rate in spray water modeling | Behnam Ghadimi | Main CFD Forum | 0 | June 8, 2013 15:48 |
Divergence after change in mass flow rate in two phase flow | meetsunilkale | FLUENT | 1 | March 25, 2013 03:03 |
tow phase flow in 180 degree bend | akbar | FLUENT | 0 | January 28, 2004 15:52 |
phase change water to steam | Tej | FLUENT | 0 | March 24, 2003 23:21 |
