How to define fan performance curve in CFX using interpolation function?
Old   December 26, 2013, 01:49
Post How to define fan performance curve in CFX using interpolation function?
Atul Patil
atulpat is on a distinguished road
Hello friends...
I am working on HVAC analysis of data center and I have fan performance curve. But I dont know how to define fan performance curve in CFX using interpolation function. Please help me.
Thanks in advance.
atulpat is offline   Reply With Quote
Old   December 26, 2013, 04:16
How are you trying to implement the fan? As a inlet or outlet, a source term or something else?
Old   December 26, 2013, 07:20
Post
Atul Patil
Yet I have not tried but little bit I know that we can implement it at inlet using sub-domain.
Old   December 27, 2013, 04:28
You implement it at an inlet OR a sub-domain. You should not do both. You can define an inlet to follow a fan curve, or define a momentum source on a sub-domain to follow a fan curve.
Old   December 28, 2013, 00:48
Post
Atul Patil
Thanks Ghorrocks.
Yes you are right. I already worked on data center using sub-domain and it is valid only when air flow from tile is directly going into the respective server rack (i.e. tile exactly located in front of server rack and air flow directly going into server rack). I used following expression for the same case for air flow in +ve X direction
Expression for RACKFAN
massFlow()@REGION:Tile1 / ((1.2 [kg m^-3])*area()@REGION:S_INLET)
and momentum source is
-1E5 [kg m^-3 s^-1]*(u- RACKFAN)
But in most of the cases it is not like that. Hence I am thinking to use Fan performance curve and it is possible to use the curve only by interpolation function. Please help me how we can use this interpolation function. I never used interpolation function that's why I came across this problem.
regards
Atul
Old   December 28, 2013, 04:46
The tutorials give examples of interpolation functions (nt sure which one though). Alternately just inset an interpolation object and stick in a few points to see how it works. They are quite simple to use.
Old   January 1, 2014, 07:42
Post
Atul Patil
Thanks ghorrocks
If you knows any tutorials then please provide me the links.
CFX a vibration fan at a shell space kevin8843 CFX 15 November 7, 2013 21:42
Modeling a fan by the fan curve in CFX saisanthoshm88 CFX 2 November 6, 2013 04:42
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
