January 14, 2014, 04:17 |
Additional variable in multiphase flow
JESS
Hi, every1. Now i have a problem about the additional variable in a two-phase flow. In CFX-pre, an additional variable has been set to Fluid Dependent on the Fluid Models tab. And transport equation is selected for one fluid on Fluid Specific Models tab. This equation is solved in the whole domain. But i just want it to be solved in the fulid specific region. How to do this? Can you give me some suggestions? Thanks.
January 14, 2014, 04:48 |
Rep Power: 143 |
But isn't the phase which has the AV present everywhere in the domain, even if it is just about zero in some places?
January 14, 2014, 07:09 |
JESS
Thanks for your reply. Once i did a simulation on the mixing process in a water-air system using AV. When i display the contour of AV in CFD-Post, it presents everywhere. It is very strange because the tracer is just a species of water and the AV belongs to the water. Now i know i may have some misunderstanding here. What should i do to correct this? Multiply AV by a volume fraction?
January 14, 2014, 16:58 |
Rep Power: 143 |
Yes, to limit to one phase for post processing you could generate a new variable which is the AV * volume fraction.
Boudaries for bouynat driven flow with additional mass flux at inlet | Charon | CFX | 2 | April 27, 2013 08:02 |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
Ansys 11.0 CFX - solving electric potentials and multiphase flow | cfd_multiphyiscs | CFX | 2 | March 10, 2010 13:43 |
Multi_component Vs Additional Variable | Anurag | CFX | 2 | February 4, 2005 16:45 |
additional variable mass transfer in CFX5.6 | john | CFX | 1 | February 14, 2004 00:30 |
