Writing a CEL expression for y position at a specific timestep |
March 27, 2019, 18:40 |
Nick Thomas
Rep Power: 7 |
I am creating a deforming mesh and my equation for the motion is dependent of the starting position of a surface. Is there a way in CEL that I can use this value (the y position of every point on a cylinder at t=0) in a transient simulation? In other words, the y position of the cylinder will be changing but I only want to use its original position as a constant in my expression.
March 28, 2019, 04:57 |
M
Rep Power: 12 |
It should be possible but I still got some understanding problems. Is this a rigid body motion or do you actually deform the cylinder?
CFX gives you several options to perform mesh deformation. Lets say you want to displace the cylinder points by 1mm per timestep, you can use relative mesh displacement, which applies the deformation relative to the last timestep. |
March 28, 2019, 08:38 |
Rep Power: 31 |
The initial coordinates (Initial X, Initial Y, Initial Z) are available via CEL, say
MyDispX= Initial X + .... |
March 28, 2019, 14:48 |
#4 | |
Nick Thomas
Rep Power: 7 |
However, I am trying to use the Y coordinates at every node on a surface so that displacement is unique to each node on the wall. The cylinder moves at a constant velocity and then is displaced back to the start, but I am hoping each bit of the wall will relocate once it reaches a certain point. In other words the cylinder wall will be split during the displacement process. Is this possible? Trying "Initial Y@Cylinder Walls" does not work. |
March 28, 2019, 15:08 |
Rep Power: 31 |
Not sure what you are trying to do.
Recall expressions have local context, i.e. if you are evaluating MyDisp = Initial Y + 2 [cm] on the Cylinder Walls, I assume the expression is also used under Cylinder Walls where BOUNDARY: Cylinder Walls BOUNDARY CONDITIONS: MESH MOTION: Option = ... Displacement = MyDisp END END END There is no need to refer to the location, it is IMPLIED. Perhaps I need better context of what your goal is |
cel |
Display Modes | |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Outlet boundary condition in interFoam | Andrea_85 | OpenFOAM Running, Solving & CFD | 51 | July 20, 2017 14:31 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 12:27 |
Retrieve Value from CEL Expression | Charon | CFX | 2 | April 15, 2013 05:03 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 18:23 |
