Setup of a turbine stator blade conjugate heat transfer simulation
Old   February 7, 2014, 04:53
Default Setup of a turbine stator blade conjugate heat transfer simulation
AGNIMITRA
mitra22 is on a distinguished road
Hi!
My objective is to carry out a very simple conjugate heat transfer simulation and obtain a temperature distribution on a stationary blade surface.
1)Blade surfaces and the end walls have been given as adiabatic walls.
2) I have not initialized the solid and fluid domains.
3)I have set a conservative interface flux near the interfaces.
Is it because of the ADIABATIC WALL condition that i am getting a constant blade temperature distribution all over the blade??? I feel there is some issue in my understanding of the numerical setup of the problem.
In the solid domain : heat transfer I have set the thermal energy option . Is it correct?
Please , if possible read it and Guys please point out the silly mistake i am making.
Thanks!!!
mitra
Last edited by mitra22; February 7, 2014 at 06:16. Reason: specified irrelevant details
mitra22 is offline   Reply With Quote
boundary conditions, fluid structure interface
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 06:33
CFX conjugate heat transfer problems dingsheng1206 CFX 7 February 13, 2014 13:29
Heat transfer simulation in electric motor by using fluent thuanckdlvn FLUENT 1 March 20, 2013 06:32
Conjugate heat transfer kiteguru CFX 2 January 9, 2012 15:57
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
