geometry import problems (STEP into ICEM)
Old   March 17, 2008, 06:18
Default geometry import problems (STEP into ICEM)
Toralf
Hi all,
I would like import a *.stp-file in ICEM 11. The geometry-export was done in Pro/E. Following error message comes: Reading Complete... Done. Tetin file ./*.tin does not exist. I do not use the 5.1 Step Translator. I have the *.stp-file close to C:/ and the file name is short and without any underlines. In Pro/E there are only few options for the export and I tried every combination. Please, can give somebody an advice?Thank you and greetings. Toralf
Old   March 17, 2008, 06:45
Default Re: geometry import problems (STEP into ICEM)
Rogerio Fernandes Brito
Use SolidWorks to import, after that, save as igs file and import on icem cfd!
Old   March 17, 2008, 07:21
Toralf
Hi Rogerio,
unfortunately our Pro/E cannot export in SolidWorks (*.SLDPRT). Thanks for your post. Toralf
Old   March 17, 2008, 09:42
myron
You could also try ACIS (.SAT or .SAB) export from ProE. What version of ProE are you using?
Old   March 18, 2008, 08:15
Toralf
Hi myron,
it works. But I have used the Design Modeler. In ICEM does not work again. Mysterious.
Old   December 8, 2011, 05:02
Mario Herrera
mario_hc68 is on a distinguished road
I had the same Problem today and it seems to be a Bug in ICEM-CFD because I couldnt open the Step-File but the guy sitting next to me could open the same Step-File without a problem....
mario_hc68 is offline   Reply With Quote
Old   December 8, 2011, 05:13
stefan23 is on a distinguished road
Maybe try creating a new project before importing the step-file, then it should work.
stefan23 is offline   Reply With Quote
Old   December 8, 2011, 05:40
Parasolid is a much more reliable format for the ANSYS products. If you can convert it to parasolid you will probably have more success.
ghorrocks is online now   Reply With Quote
Old   August 21, 2013, 13:53
apex is on a distinguished road
Hi everyone... am having the same problem Tetin file Part1.tin does not exist.... except tht i did mine on catia v5r19...... can you guys help me plz
thanks
apex
apex is offline   Reply With Quote
Old   August 22, 2013, 09:50
Yu Omori
dbagtbag is on a distinguished road
Don't use step files or igs for ICEM. Even after you import them dealing with the imported geometry in ICEM is a pain. Use Parasolid, its much better. If you MUST use step or igs you can import them by forcing ICEM to use the proper .igs or .stp extensions.
dbagtbag is offline   Reply With Quote
Old   March 7, 2014, 21:17
Default it works this way.
  #11
taha
taha8 is on a distinguished road
change your working directory from C:\Windows\system32 to your local folder. Now import your step file. It won't show any error. No need of using step translator as well.
taha8 is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
flow over an airfoil 3d ( Geometry on icem cfd ) dfmona Main CFD Forum 0 April 13, 2010 23:32
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 02:49
