Monitor Averaged Value of a Quantity on a Surface |
March 3, 2014, 16:05 |
Rep Power: 13 |
In Fluent, we can define a plane or surface and monitor the convergence of the average value (e.g. mass weighted average, area weighted average, etc) of a quantity during the calculation. Can we do the same thing in CFX? I could only find monitor point in CFX and that is only monitoring the convergence of the value of the quantity at a particular point (not average across a surface).
March 3, 2014, 16:38 |
Rep Power: 143 |
Yes, you can do this. Assuming the surface object you want to average over is called "Surface", then set a monitor point with the CEL expression:
areaAve(u.residual)@Surface I think that will work. I might have the wrong variable name for the residual, better check that. |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
import solids | Alessio85 | STAR-CCM+ | 5 | November 11, 2011 13:16 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
