Variable and expression doubt
Old   April 5, 2014, 17:18
Default Variable and expression doubt
Talles Caio
TallesC is on a distinguished road
takes personal sequinte put the boundary condition on the surface of a pipe:
Q = constant * ( Tp^ 4 - Ts ^ 4)
where:
* Tp - is constant.
* Ts - the surface temperature of the tube
* Q - heat supplied.
ie, Q and Ts are unknown, is how I do it? if yes how to call Ts in expression?
TallesC is offline   Reply With Quote
Old   April 5, 2014, 22:52
Erik
evcelica is on a distinguished road
HeatFlux = Constant [W/m^2/K^4] * (Tp[K])^4 - (Temperature^4))
evcelica is offline   Reply With Quote
Old   April 6, 2014, 21:51
Talles Caio
but Ts is the temperature at the surface, and the temperature is variable across the field, is not it?
my advisor, said it could be done as follows, as the condition of no slip near the wall, the heat conduction mechanism is thus the condition would be:
************************ K * dT = const * (Tp [K]) ^ 4 - (TS ^ 4))
Ts just found on the surface, it is possible to do this?
Old   April 7, 2014, 01:10
Antanas is on a distinguished road
You set it as BC, so CFX takes Temperature at that boundary. Do like evcelica wrote. What's the problem?
Antanas is offline   Reply With Quote
Old   April 7, 2014, 09:52
Talles Caio
Ok!!!Boundary type is wall right???
Old   April 8, 2014, 15:25
Talles Caio
Guys, simulation show error of overflow, but when put Q =constant its working, any idea this causes the problem???
Old   April 8, 2014, 19:38
This is an FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
So in your case it looks like the introduction of a variable Q (assuming that is what you have done) is not numerically stable.
Old   April 8, 2014, 23:31
As Glenn mentioned you have strong dependence of source term on solution (temperature). If you set your source through flux option solver most likely fail. Try to use the idea proposed here
Old   April 13, 2014, 00:16
Thumbs up
Talles Caio
Thank you so much Antanas!!! your idea working....
Use expression instead of variable Anna Tian CFX 2 December 4, 2012 19:36
Additional variable as output of an expression Chander CFX 1 November 22, 2011 13:54
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
variable 'r' in 'Expression' of CFX-Pre Atit Koonsriusk CFX 6 June 19, 2006 07:48
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
