December 30, 2013, 09:52 |
How to disable solution of an equation?
JESS
Rep Power: 15 |
Hi, all.
The solution for a steady flow field is converged, now i want to solve an additional variable based on the preceding result. The flow equations may be solved again. Is there any way to disable solution of flow equations and solve the transport equation for additional variable only in CFX? Thanks a lot. |
December 30, 2013, 16:57 |
Rep Power: 143 |
Yes: Use the expert parameters to turn the flow, turbulence, thermal and any other equation solvers off. You can access this in CFX-Pre under options>expert parameters (I think that is where it is - it will be under the solver over-rides tab), or CEL.
December 30, 2013, 21:45 |
JESS
Rep Power: 15 |
Yes, you are right. It is in expert parameter panel called "model over-rides". Thank you very much.
April 16, 2014, 12:14 |
Rep Power: 15 |
In a multiple-domain simulation is it possible to turn off the equations just for one domain and not for everyone? Expert parameters turn off equation for every domains |
April 16, 2014, 19:46 |
Rep Power: 143 |
No, you cannot turn off specific equations in specific domains.
Display Modes | |
Some problem of "Qcriterion.mcr& | yuyuxuan | Tecplot | 9 | February 12, 2016 04:27 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
ERROR #001100279 - CFX 13 - transient run | Zigainer | CFX | 14 | December 9, 2011 14:22 |
Iterative solution to Poissons Equation | Phiper | Main CFD Forum | 4 | December 10, 2010 02:58 |
Analytical Solution of the equation | Newbie | Main CFD Forum | 3 | August 20, 2004 04:17 |
