April 13, 2014, 23:24 |
CFX-pre
Niraj Pandya
Rep Power: 12 |
How do I add a Refrigerant (fluid) in cfx-pre which I want to use it for my simulation with material properties like vapor density, Enthalpy, vapor Cv, vapor Cv, Heat of vapor, Molar mass, thermal conductivity, viscosity which are temperature dependent and who's values varies with temperature.
I tried adding through insert material in cfx but in that you can only add constant value for all the property, I want to add a tabular data, also there is some NASA format as well as TASCflor RGP format which allow us to add material property differently but I don't how to use that formats. Or can I add my material in Workbench in Engineering data and use it in cfx? Or can I add .ccl file containing my material to the material library and import through that? |
April 14, 2014, 02:00 |
Rep Power: 143 |
All the parameters you mentioned can be made expressions or interpolation functions. Some can also be RGP format and a few others as well. Do the CFX tutorials as some of them show how to set customised material properties.
April 14, 2014, 15:03 |
Niraj Pandya
Rep Power: 12 |
Thanks for the reply.
I can write expression for the properties for a constant value but how can I make them vary with temperature, as my simulation progresses there will be change in temperature according to which fluid properties will also change. Also can you give me more knowledge on RGP and NASA format on how to get there different coefficient values. |
April 14, 2014, 18:45 |
Rep Power: 143 |
You just write expressions or an interpolation function which is a function of temperature (T). It is very easy.
The RGP and NASA formats are described in the documentation. |
April 15, 2014, 14:17 |
Niraj Pandya
Rep Power: 12 |
OK, Thank you so much.
May 7, 2014, 06:11 |
help me please
mahboobeh
how can i define interface for two fluid in CFX?
and how can find and plot interface's velocity vs time? |
May 7, 2014, 07:20 |
Rep Power: 143 |
Have you done the tutorials?
May 7, 2014, 12:37 |
mahboobeh
I have ANSYS CFX-Pre User's Guide.
can it help me? |
May 7, 2014, 18:42 |
#9 |
Rep Power: 143 |
I am referring to the ANSYS CFX tutorials, which should be installed along with the CFX-Pre documentation.
Error while opening cfx file in cfx pre | pks126 | CFX | 9 | June 11, 2018 11:00 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 07:55 |
CFX Pre Domains for centrifugal pump | MechKim | CFX | 1 | September 24, 2012 08:06 |
CFX Pre Hide symmetry symbols | alvid | CFX | 2 | August 15, 2007 11:34 |
CFX 10 -pre and -post problams on Linux | Henry Liu | CFX | 3 | June 22, 2006 06:57 |
