Modeling internal flow with normal velocities on walls- permeable walls |
April 27, 2014, 07:07 |
Ali Madayen
Rep Power: 12 |
Hi everyone.
I'm trying to simulate blood flow in a vessel, where the boundary condition on wall for u is no slip, but for v is a constant definite value. In other words, wall is permeable in y direction. How can I apply this kind of boundary to my problem in CFX? Tnx for your help |
April 27, 2014, 18:27 |
Rep Power: 143 |
I presume you mean u is in the tangential direction and v is in the normal direction.
The easiest way of doing this would seem to be a normal no-slip wall with a mass source/sink applied to the wall which gobbles up fluid at your prescribed rate. |
April 27, 2014, 18:35 |
Ali Madayen
Rep Power: 12 |
Tnx for your reply
your assumption is correct. But now the question is what is the relation between source/sink intensity and the normal velocity? Question is posed regarding that the problem specifies the normal velocity on the wall, and nothing more. |
April 27, 2014, 18:55 |
Rep Power: 143 |
Make the magnitude of the mass sink a function of the wall shear stress. I would not make it a function of normal velocity as it will then be mesh dependent.
April 27, 2014, 19:05 |
Ali Madayen
Rep Power: 12 |
Real Smart.
I will try it for sure |
April 27, 2014, 19:06 |
Ali Madayen
Rep Power: 12 |
Real smart, I will try it for sure
Thanks a lot, friend. |
normal velocity, permeable wall |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
flow modeling and incompressible analysis of internal flow of effervescent injector | umar959 | FLUENT | 0 | November 15, 2011 03:32 |
Modeling of water infiltration into a tank containing a permeable soil | idir | CFX | 8 | September 16, 2011 06:40 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
