Negative value for static enthalpy calculation in CFD Post
Like Tree2Likes
  • 1 Post By ghorrocks
  • 1 Post By Opaque
Old   April 29, 2014, 02:01
Default Negative value for static enthalpy calculation in CFD Post
Bostjan
brajh11 is on a distinguished road
Anybody know what exactly means negative value for static enthalpy in CFD Post?
I have seen in material definition and the reference state is 25 C and 1 atm.
For example:
areaAve(Static Enthalpy)@Outlet = -1.53639e+006 [J kg^-1]
areaAve(Static Enthalpy)@inlet = -2.5098e+006 [J kg^-1]
areaAve(Static Enthalpy)@Burner_1_Air_inlet = -2198.38 [J kg^-1]
brajh11 is offline   Reply With Quote
Old   April 29, 2014, 03:33
Negative enthalpy simply means the enthalpy is less than the reference value. It is the differences in enthalpy which are important.
njdyck likes this.
Old   April 29, 2014, 04:03
Bostjan
Where is possible to check the enthalpy for standard material (for example CO, CO2, H20, N2, O2,...) at reference state if material properties is selected in NASA Format?
Old   April 29, 2014, 07:50
You define the reference point in the materials tab.
Old   April 29, 2014, 07:53
Bostjan
I know. I have defined reference point at 25 C and 1 atm but I need to know the value for enthalpy at defined reference point - which value for standard materials (CO, CO2, H2O,....)if material properties is selected in NASA Format. How is possible to get this value?
Old   April 29, 2014, 17:22
Erik
evcelica is on a distinguished road
Like Glenn said, the value is arbitrary, it is based off some arbitrary zero point. If you want to match something, NIST RefProp is a great source for fluid properties. I.m sure there are tables in textbooks and online as well.
evcelica is offline   Reply With Quote
Old   April 30, 2014, 00:25
Opaque will become famous soon enough
Check your material definition, and reference state settings.
Under Material: MyMaterial, there should be a section named Reference State, and you can set, or check the following:
Reference Temperature
Reference Pressure
Reference Specific Enthalpy
Reference Specific Entropy
If your material uses the NASA format to define the specific heat capacity, the reference state is implicit within the coefficients, and you will have to evaluate the NASA expression at the reference state (usually 25 [C] and 1 [atm]..
Opaque is offline   Reply With Quote
Old   April 30, 2014, 01:41
Bostjan
If under Material select reference specific enthalpy: -1.15334e+07 J/kg and reference specific entropy: 0 J/kgK at reference state 25 C and 1 atm, what is the value for specific enthalpy and entropy at 100 C? same value?
Old   April 30, 2014, 02:53
A quick look at the ANSYS CFX Solver Theory Guide / Basic Capability / Documentation Conventions / Variable Definitions / Static Enthalpy will help understand how all the pieces are connected.
It explains how static enthalpy is computed for the different materials, and how the reference value is used.
njdyck likes this.
Plotting the Viscosity Contour in CFD Post ashtonJ FLUENT 3 June 2, 2015 12:06
Collect transient results CFD POST mortain CFX 15 April 17, 2015 08:29
How can I include scalable text in my images from CFD post? ziggo ANSYS 0 October 31, 2013 11:36
FEA results in CFD Post delaneyluke CFX 1 October 25, 2013 06:16
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 08:37
