CFX, Output controll, monitor?
3 Attachment(s)
Trying to make some point through the draft tube to calculate the mass flow, velocity and pressure. These also will help to draw pressure chart over all the draft tube and study the pressure recovery. I tired in the beginning to add point(as you add plan for example) in the resultant(post) but it didn't work. Then I found there is an another way through adding Monitor i output control i setup. The attach picture shows the problem, do you any idea or another solution?
do you want to open the .res file or monitor point data?
I cannot understand the problem, but if you want to get monitor point data, you have to save output file. it is an excel file. you can find it in cfx solver. when the simulation is running, you can save it.
ok.. yeah, if you want to find data, after the simulation, then you can use cfd post. if you want to get data with the time, then you can use what I have suggested before.
