May 3, 2014, 03:30 |
CFX, Output controll, monitor?
bashar
Rep Power: 12 |
Trying to make some point through the draft tube to calculate the mass flow, velocity and pressure. These also will help to draw pressure chart over all the draft tube and study the pressure recovery. I tired in the beginning to add point(as you add plan for example) in the resultant(post) but it didn't work. Then I found there is an another way through adding Monitor i output control i setup. The attach picture shows the problem, do you any idea or another solution?
May 9, 2014, 05:58 |
S.Bogoda
Rep Power: 13 |
do you want to open the .res file or monitor point data?
May 9, 2014, 09:58 |
bashar
Rep Power: 12 |
It was the idea to make point through the draft tube to calculate pressure in every point. I found there is possible to calculate through great monitor through the tube but it didn't work. I don't know why?
May 9, 2014, 10:13 |
S.Bogoda
Rep Power: 13 |
I cannot understand the problem, but if you want to get monitor point data, you have to save output file. it is an excel file. you can find it in cfx solver. when the simulation is running, you can save it.
May 9, 2014, 10:16 |
bashar
Rep Power: 12 |
Thank you, I didn't know that, I am going to check again. I also found another way to great points on post-CFD like you great plan. These points help med to calculate the pressure and velocity through the tube.
May 9, 2014, 11:28 |
S.Bogoda
Rep Power: 13 |
ok.. yeah, if you want to find data, after the simulation, then you can use cfd post. if you want to get data with the time, then you can use what I have suggested before.
May 9, 2014, 11:29 |
bashar
Rep Power: 12 |
Easy way to export monitor data from CFX out file | jonny_b | CFX | 30 | January 15, 2018 17:51 |
CFX output for ParaView | siw | CFX | 8 | March 24, 2016 08:02 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Add user define monitor in CFX Solver | Zaidun | CFX | 0 | April 17, 2006 14:57 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
