May 22, 2014, 14:00 |
LES mesh requirement
Majid
Rep Power: 12 |
Hello everybody
I am simulating turbulent flow in an annulus using LES in CFX the pipe is 8 meter long and in the meshing I used hexahedral mesh along with inflation layers at both walls of the annulus, in the streamwise direction I have meshes of constant length (5 mm) but much finer mesh in cross sectional area to capture near wall effect. No as I now LES filter applies based on mesh size I want to know which characteristic length is taken as cut off size between large eddies and smaller one which are not simulated directly. I thought this length is (V)^(1/3) where V is the volume of each control volume but I am not sure of it. I appreciate your time in advance |
May 22, 2014, 18:47 |
Rep Power: 143 |
Look in a turbulence textbook like "Turbulence Modelling for CFD" by Wilcox for the answer to this.
But be aware that it is not a cut-off (which implies to me a sharp transition). The filter is done by mesh resolution and the cut-off is occurs over a range, more like a low-pass filter. |
May 23, 2014, 10:10 |
Majid
Rep Power: 12 |
Thanks Glenn
I think the filter is a box volume filter which dictates the smallest scale of the resolved eddies and that tells me volume is more important than one characteristic length. Cheers, |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
