June 19, 2014, 06:33 |
Transient or Transient Blade Row?
Hi all.
I'm now simulating the transient flow field in a torque conveter, which is a closed turbomachine with one stator and two rotors. In order to save time and memmory, I use a one-blade passages for all three components. I have two options for transient simulation - Transient and Transient Blade Row. Actually I have used both models and compared the outcome torques of torque converter, which showed good aggreement. Here is my question: Can I apply transient solution for one-pitch blade model? What's the difference between transient model and transient blade row model? Thanks in advance! Cheng |
June 19, 2014, 07:54 |
Rep Power: 143 |
Transient rotor stator is a full and direct transient model. Transient blade row is similar but does some magic on the interface to allow you to account for unequal pitches. As your two rotors probably have the same number of blades you should not need Transient blade row and they should be equivalent.
June 19, 2014, 08:03 |
#3 | |
So if I have pitches near unit, I can use the transient rotor stator method? Otherwise I should use the transient blade row method? |
Display Modes | |
Question abt the CFX tutorial regarding scaling of the rotor blade row! | MAP7 | CFX | 0 | April 24, 2014 06:46 |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 05:09 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 23:43 |
[ ICEM ] meshing a blade compressor row | AndreaDB | ANSYS Meshing & Geometry | 0 | May 8, 2011 22:34 |
Problem with transient solution of flow past a row of cylinders | jostanek | Main CFD Forum | 0 | January 6, 2010 13:16 |
