Can CFX use a material from Fluent's library?
I need to perform a simulation using nitric acid. Fluent has this material built into its database natively. CFX does not.
Is there a way to import the material library from Fluent into CFX? Thank you. :) |
No. Your best bet is to manually transcribe all the important physical properties from Fluent into CFX.
Thanks Glenn. I thought as much.
