How to get the results target level????
1 Attachment(s)
hi every one
:confused: i defined a isosurface and plane in cfx post, my goal is get result at intersection isosurface & plane As shown in the figure below. please help me How do this????? thanks a lot |
Draw contours of volume fraction on your plane. Extract the contour line you want as a polyline. Or use the intersection of the two objects as a polyline.
:confused:dear ghorrocks
i want result Exactly at intersection plane & isosurface, How to do this using polyline? in polyline in geometry tab i select method with boundary intersection and in boundary list Does not exist plane or isosurface, only intersect with exist select plane & isosurface, therfore i cant define intersection plane & isosurface. I mean you did not notice And the urgent need to solve my problem, please help me If you can explain a little more i confused. Thank you very much for your assistance |
I stated another option as well - you can extract a contour. This one definitely will work.
And if you need urgent assistance then pay for ANSYS support and contact them. Nobody gets paid here on the forum and we will answer questions when we get around to it. |
