CFD analysis on regenerative pump using ANSYS CFXs
Dear friends, I am conducting a CFD analysis on regenerative pump using ANSYS CFX (MRF approach). Please see the model attached. http://s9.postimg.org/cugg0fogv/image.jpg
The model consists of 3 regions- inlet domain ,impeller domain and outlet domain. Impeller is rotating at 2800 rpm. At inlet , total pressure =101953pa and at outlet, mass flow rate =0.76kg/s . The pump is expected to produce 25 m head.But from analysis it is found that ,pressure at the outlet of the pump is negative. See the pressure distribution> http://postimg.org/image/7t53erj3j/ Can anyone help me with this problem... Thanks in advance.. :) |
Hi Rakesh!
I am facing the same issue. Was it resolved in your case? if yes, then please do help. |
You will need to show details of cfd domain geometry, boundary conditions and interface modelings.
