Rep Power: 13 ![]() |
Hello everyone,
I recently set up an Ansys CFX simulation to do a mesh study for a 2D airfoil using the CFX Gamma Theta Model. The results were quite good for an airfoil without any camber. Since I switched to an airfoil that does have camber (NACA1408) none of my simulations converge any more. Since I want to perform a mesh study I have been varying all relevant mesh parameters (Yplus, Cell sizes, Cell expansion rates, ...). I am trying different timesteps at the moment. Also, since the simulation already produced good results for a non-cambered airfoil there shouldnt be any fundamental mistakes. Do you guys have any ideas what I could look into to solve the problem ? Also, if you need any more information please be sure to tell me ! This is only the second time I am using cfd-online so I might not be really good at presenting my problem. Sorry about that ! Best Regards, Leif |
Here is some more information ... made a new post since I couldnt find an option for adding attachments after submitting a post.
Attachments are a picture of what my residuals look like and the .out file of the simulation (i cut out most of the timesteps in order to make the file size suitable) |
Rep Power: 145 ![]() ![]() ![]() ![]() |
Hi ghorrocks,
thanks for your reply. I already read through http://www.cfd-online.com/Wiki/Ansys...gence_criteria and also the best practice instructions from Ansys. Pretty much tried anything except running the simulation in transient mode. - mesh quality is fine by ICEM check and the same mesh (only a small difference between cambered - non cambered) already produced good results for a non-cambered airfoil - simulation physics should be fine for the same reason - experimenting with different time steps at the moment but I do not see a reason why the timestep should have to be so different from non-cambered airfoil simulations to obtain convergence I am reluctant to do the simulation in transient mode though since I figured there should be a way to obtain usable results via steady type simulations. |
Definitely try larger time steps. Also try local time stepping for a bit too. If that does not work you may be forced to run transient.
Transition models can resolve a laminar separation bubble at the transition point. This bubble often jiggles around - and this is why steady state simulations of this type of flow are problematic. So I would not be surprised at all if you end up needing a transient simulation. |
Thanks a lot for quick and helpful replies !
Will try both and post again when I manage to obtain convergence. |
Display Modes | |
Gamma- Re Theta Transition Model CFX Roughness Modeling | prakhar_32 | CFX | 3 | June 18, 2014 18:52 |
Laminar-to-turbulent transition modelling using SST and SST Gamma Theta models | ttu004 | CFX | 3 | June 13, 2014 06:43 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
Literature on Gamma Re Theta model | Nick R | CFX | 1 | May 23, 2011 05:31 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
