Efficiency prediction of centrifugal pumps in CFX
Old   August 1, 2014, 08:18
Question Efficiency prediction of centrifugal pumps in CFX
Ji Pei
peiji1984 is on a distinguished road
Dear all,
I have done a lot of simulations for centrifugal pumps in CFX, and I found that the efficiency prediction (ρgQH/Mω) is not accurate, especially for a centrifugal pump with very large flow rate as design point, for example, 10000 cubic meter per hour. At design point, the head result is acceptable, but the efficiency result is obviously lower than the test data. Does anybody have the experience about this? I will be very appreciated if you can explain to me.
Thanks a lot!
Ji
peiji1984 is offline   Reply With Quote
Old   November 19, 2022, 03:23
Ahmed mohamed
Ahmedelshetiry is on a distinguished road
I have the same problem. Did you get any solution?
Ahmedelshetiry is offline   Reply With Quote
Old   November 19, 2022, 09:24
Daniel
zacko is on a distinguished road
How are you computing the Moment ? I assume you use the torque variable in Post of blade, hub and shroud ? Are you modeling the side chambers ? This is obviously a simplification which will result in a difference in test data and simulation data. But, in my experience, the Efficiency would be higher then (without side chambers).
By which magnitude do the test data and CFD result differ ?
Convergence was reached, correct ? Is the mesh accurate enough ?
Are you evaluating your hydraulic data at a similar position like the test data, e.g. suction and discharge pipe position ?
zacko is offline   Reply With Quote
centrifugal pump, efficiency
Cyclone separation efficiency using CFX Benfa CFX 20 April 9, 2019 13:10
Particle Interaction is CFX; Adding Interparticle Attraction such as Van Der Waals FrankS CFX 11 November 12, 2013 19:53
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX or STAR-CD for Gerotor pumps? learningCFD Main CFD Forum 1 September 22, 2007 05:14
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
