How to calculate the average of torque in transient Ansys CFX Simulation
Like Tree1Likes
Old   April 3, 2013, 07:18
Default How to calculate the average of torque in transient Ansys CFX Simulation
Benjamin Stanke
xtphgu is on a distinguished road
I am trying to calculate the power of a wind turbine in a transient simulation. My simulate of a rotor blade works well but as a result I need the torque of the blade as mean over many time steps. For my CFD simulation I am using Ansys CFX 14.5.
I can get the torque in CFD-Post ->Calculators -> Function Calculator -> Fuction:torque (Location). But just for the current time step I chose.
Those anyone know how I can get the torque Results over all my time steps? As a plot, a file or somehow else? Thanks ahead.
xtphgu is offline   Reply With Quote
Old   April 3, 2013, 07:28
I would export the torque versus time history and do the averaging in another package like excel, matlab or whatever you wish. To get the full time history, make a monitor point set to torque_x/y/z()@location and then export this point in the solver manager.
Old   April 3, 2013, 08:07
Benjamin Stanke
Thanks @ghorrocks. It works just perfect in this way!
Old   April 4, 2013, 09:27
Matthias Voß
mvoss is on a distinguished road
in case you did not set the monitor point before calculating, here is a little script which loops through each time step for a given res-file. start it from the cfx command line via cfx5perl. res-file needs to be next to the script (or viceversa).
>load filename=YOURRESFILE.res
! 	$Liste = getValue("DATA READER","Timestep List");
!	@TIMELIST = split(/,/,$Liste);
!	print "@TIMELIST \n";
!	open OUT, ">YOURDATA.dat";
!	print OUT "Time;Massflow Inlet;Massflow Düse;Massflow Mündung\n"; #HEADER
!	foreach $TS(@TIMELIST){
> 		load timestep = $TS
! 		print "calculating timestep $TS \n";
!		($time, $timeunits) = evaluate("Time");
! 		$pin=massFlow("INLET");
! 		$pduese=massFlow("Domain Interface 1 Side 2");
! 		$pmuendung=massFlow("Domain Interface 2 Side 1");
!		print 		"$time;$pin;$pduese;$pmuendung \n";
!		print OUT 	"$time;$pin;$pduese;$pmuendung\n";
!		close OUT;
> close
n0ukh3z007 likes this.
mvoss is offline   Reply With Quote
Old   March 13, 2014, 13:19
Fernando Ruviaro
Fernando R. is on a distinguished road
Hello. I can't set a torque monitor point. When I created it, torque wasn't in the output variable list. I've typed "torque_z()@pa" ("pa" was the name of the surface I've wanted to evaluate the torque around the z axis) in the box and it just goes empty again as I press "Apply". Is there any special way to do it?
Fernando R. is offline   Reply With Quote
Old   March 13, 2014, 13:36
Benjamin Stanke
"torque_z()@pa" should actually work. Do you need torque over time or are you simulate 'steady state'?
Old   March 13, 2014, 13:43
Fernando Ruviaro
Torque over time. I'm simulating a vertical axis wind turbine and I need in the torque vs angular position curve.
Old   March 13, 2014, 13:53
Benjamin Stanke
If you create a output expression with "torque_z()@pa" in CFX-Setup you should get the curve as User Points in CFX-Solver.
Old   March 13, 2014, 14:18
Fernando Ruviaro
I will try it.
Old   March 13, 2014, 15:16
Fernando Ruviaro
Is it what I should do? I type "torque_z()@pa", press enter and apply and the field doesn't go empty. But, if I press ok, then open again the monitor point, the output variable goes automatically to "Absolute Pressure".
Old   March 13, 2014, 16:00
Benjamin Stanke
Ok you have to change the Option drop down menu from "Cartesian Coordinates" to "Expression" then CFX will accept the torque-espresssion. God luck
Old   March 14, 2014, 12:35
Fernando Ruviaro
It works now. Thank you very much
The unit of the torque measured is relative to the solution units, right?
Old   March 14, 2014, 15:56
Fernando Ruviaro
I was testing the results with this method and noticed that the value of torque obtained with the monitor point differed a bit from the value acquired by using the 'Function Calculator' (in Calculators) in a given timestep.
So, to have an idea of this difference I've made a simple simulation of a rotating "square" in an air flux, first with it still, to have the inicial values, and then with it moving, and a monitor point measuring the force in the x direction in the sides of the square (defined as "paredes").
After, I've compared the data exported from the monitor point and the force in the x direction evaluated at each timestep using the 'Function Calculator'. The data is shown in the third image (in the table, data refers to "exported data", and manual to data obtained with the function calculator).
It seems that the x axis using the monitor point is refers to a frame of reference fixed in the rotating domain. I've tried marking the "Coord Frame" box and selectinig the "Coord 0" (the only one that appear), but the result is the same.
How can I export the data referred to the global coordinate system?
Old   April 24, 2014, 11:13
Default Average Temperature
  #14
Disabled
anon_f is on a distinguished road
The subject treated here is very interesting.
I would like to ask a question in my turn. My simulation on CFX is on heating a large block into contact with a combustion chamber. A heat flow is transmitted to the block and the temperature of the block varies with time.
So I get for each time step the temperature profiles of tho block. When I want to see the transient variation of the block temperature with XY - transient or sequence in Chart I can do it for points only (not all the domain).
Does anyone can tell me, please, how to plot the average temperature of all my block function of time? Or how to export at each timestep the average temperature of my block.
Thank you in advance for your help.
anon_f is offline   Reply With Quote
Old   April 24, 2014, 12:29
Matthias Voß
You can create an expession like volumeAve(T)@block And use it instread of the Point in the Chart schematic.
For the export via script see #4 above.
Old   April 24, 2014, 14:08
Disabled
Thank you so much.
Old   May 16, 2014, 07:00
Walter
walter.vahlbruch is on a distinguished road
Thank you so much for all of this information!
I would like to monitor the pressure of a moving wall.
Unfortunately it doesn't work like that: "pressure()@MOVING_WALL"
Ansys doesn't know the word "pressure". What can I do?
walter.vahlbruch is offline   Reply With Quote
Old   May 16, 2014, 09:22
Edmund Singer P.E.
singer1812 is on a distinguished road
The variable goes into the parenthesis. The first part is how you want to evaluate the variable. In your case for example:
areaAve(Pressure)@moving_wall
maxVal(Pressure)@moving_wall
minVal(Pressure)@moving_wall
can give you the area average, the max value and min value. Please look up CEL in the help.
singer1812 is offline   Reply With Quote
Old   May 16, 2014, 10:40
Walter
Thank you very much! I'm new in CFX. I will look up CEL.
Saved me a lot of hours!
Thank you!
Old   January 25, 2016, 06:27
Ronald Thompson
dynamic is on a distinguished road
Hi Glenn,
I want to do something similar with what you showed Benjamin how to do, but I'm using fluent, I want to export the torque at each time step of my analysis to determine what is the optimum angle of attack throughout the rotation,
I tried creating a monitoring point and setting the expression as stated above in the calculation activities in fluent but when I run it is says invalid
what am I doing wrong thanks
dynamic is offline   Reply With Quote
Reaction with CFX (transient simulation) ameen0602 CFX 2 May 4, 2012 16:11
Verifying results for a wind turbine blade simulation in ANSYS CFX Joystix CFX 3 April 27, 2012 17:52
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
Ansys FSI and CFX (valve simulation) farianka ANSYS 0 April 17, 2011 16:20
MFX: weired force transfer from cfx to ansys zyf CFX 3 October 7, 2006 03:08
