September 23, 2014, 02:06 |
[Q] Nodes and parallel cpu no.
Jinwhan Ryuk
Rep Power: 13 |
Global No. of Nodes=598307, serial run is faster than 6 core MPI parallel CPU. CPU:Intel(R) Zeon(R) CPU E5-2643 v2@3.50GHz, 64.0GB RAM, 64bit Win 7 OS
I am solving coal combustion problem. I used to use maximum core number for parallel above half million nodes number. Does anyone suggest me how to set proper nodes number per CPU no.(core)? |
September 23, 2014, 07:11 |
Mr CFD
Rep Power: 14 |
Read the release notes for your Ansys version. It should be in there. There is such a thing as parallel slowdown.
September 23, 2014, 11:03 |
#3 | |
Rep Power: 32 |
From Intel website,
October 6, 2014, 22:14 |
Thank you very much.
Jinwhan Ryuk
Rep Power: 13 |
Thank you very much all of you.
October 10, 2014, 05:58 |
Erik
Rep Power: 23 |
The E5-2643v2 is a 6 core processor. This is different from the E5-2643, which is a quad core. Either way, I usually only run 4 Processors on my 6 core as well. But I've never had it slow down when running 6 cores. Are you comparing wall time, or CPU time?
[ICEM] Assigning different number of nodes to parallel edges | Rohit | ANSYS Meshing & Geometry | 3 | September 22, 2017 09:16 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
identify interface boundary nodes in parallel | emdoran | Fluent UDF and Scheme Programming | 0 | September 29, 2010 23:11 |
CFX-5.7.1(Linux) Parallel - 4 CPU Machine | James Date | CFX | 6 | June 14, 2005 18:03 |
Minimum number of nodes to run CFX in parallel | Rui | CFX | 3 | April 11, 2005 20:46 |
