October 1, 2014, 06:49 |
CFX wall placed error
cfd_guy
Rep Power: 12 |
hello,
I am modelling a single passage of a centrifugal compressor with splitter blade. i have meshed using turbogrid. I am getting the problem of 'wall is placed at x% of the outlet.' How can this be resolved? I am using periodic interfaces. |
October 3, 2014, 01:00 |
Ali Madayen
Rep Power: 12 |
Hi
Basically this message (not always error) means that at the outlet boundaries, backflow is happening. Depending on the problem you are solving, this might be physical, for instance consider a curved tube, at lower radius backflow is physical and possible. But what to do, first check if this is physical or not. does the percentage decreases as the residuals reduce, or it converges to a constant value? if backflow is physical, during solution the area that it covers will converge to a specific value. then, as error instructs, change your BC. if not, check your problem again and refine your mesh. As a personal experience, try to put the outlet BC in a distance that your are sure fluid flow is fully-developed. Best |
October 3, 2014, 09:37 |
Mr CFD
Rep Power: 14 |
Move your outlet to a region far from the compressor.
A quick fix is to change the outlet to an opening. But you'll face rebustness issues if you do this. |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
