Home > Forums > CFX
Real Stack Memory ERROR
Old   October 26, 2014, 22:13
Question Real Stack Memory ERROR
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear All,
I am stuck with the following error:
_________________________________
*** INSUFFICIENT MEMORY ALLOCATED *** |
| ACTION REQUIRED : Increase the real stack memory size. |
| Details : |
| Requested space : 201528 words |
| Current allocated space : 191808656 words |
| Current used space : 191757021 words |
| Current free space : 51635 words |
| Number of free areas : 1 |
Details of error:-
Error detected by routine MAKDAT
CDANAM = IELG251 CDTYPE = REAL ISIZE = 201528
CRESLT = FULL
I've gone through all previous threads on this error and tried to increase the memory up to 8x, but still get the same error.
This cfx set-up used to work with no error; however, after activating transient statistics and defining few new variables, the above error showed up.
Here is a summary of newly defined variable:
New Variables:
ABSPGX: abs(Pressure.Gradient X)
ABSPGY: abs(Pressure.Gradient Y)
ABSPGZ: abs(Pressure.Gradient Y)
PG: sqrt(((Pressure.Gradient X)^2)+((Pressure.Gradient Y)^2)+((Pressure.Gradient Z)^2))
In "Transient Statistics" tab, I defined few cases to find the time-average of above variables over whole flow cycle as well as between specific times.
Would be too pleased if any body can help me.
Thanks
AshtonJ
ashtonJ is offline   Reply With Quote
Old   October 27, 2014, 05:53
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
You've probably got some obsurdly long file names for your .def file. In execution control, under solver increase the solver memory allocation factor to 2.
Failing that just reduce your file names.
JuPa is offline   Reply With Quote
Old   October 27, 2014, 06:45
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Why do you think file names has something to do with it? It is the real stack which has run out of space and that has no link to the file name to my knowledge.
I have a hunch there may be a problem (ie a bug) in CFX with using Pressure.Gradient X/Y/Z and transient statistics. Can you try doing transient statistics on just Pressure? Try a work around by defining a variable like PGX = Pressure.Gradient X, then define a transient statistic of abs(PGX).
By the way: you have an error in your ABSPGZ function - you are using the Y gradient, not Z.
Old   October 27, 2014, 08:01
Ashkan Javadzadegan
Thanks Glenn and RicochetJ.
I figured it out, the problem was because of choosing the full list of transient statistics. I changed it to Arithmetic Average and it works now.
Old   October 28, 2014, 07:41
JuPa's Avatar
Mr CFD
I had an error a year or two ago where my file names were absurdly long. I received a similar error to the above. I fixed it by increasing the mem allocation factor.
Old   October 29, 2014, 06:14
Weird. But it should have been the string stack which ran out of room, isn't it?
Old   October 30, 2014, 12:16
JuPa's Avatar
Mr CFD
I haven't the foggiest. I just increased the memory allocation factor (at the time it made sense - two years later I don't know why). The mesh independent results I achieved were validated by experimental data so I was happy and didn't question anything!
Error out of sight is error out of mind!
Old   November 11, 2014, 21:47
Ashkan Javadzadegan
I've found out what causes "INSUFFICIENT MEMORY ALLOCATED" error and wanted to share it here:
This error might occur
1- if you define a lot of additional variables
2- if you want to save all transient statistics
I've had this problem for the last month and tried different ways to get rid of that error such as
1- Increasing the memory allocation factor up to 10x for “Partitioner”, “Solver” and “Interpolator”
2- Reducing the mesh from 1300,000 elements to 500, 000 elements
None of them worked
However, I fixed that problem by increasing the memory allocation factor within the CFX and also by ticking "Use Large Problem Partitioner" option and surprisingly the error is gone!
Old   September 23, 2015, 08:15
MaBe is on a distinguished road
Thxanks a lot for this advice.
For everyone: Try to changed the allocation factor in CFX-Pre instead of the CFX-Solver Manager!
This worked fine for me.
MaBe is offline   Reply With Quote
Thread Tools
Trackbacks are On
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
Compile calcMassFlowC aurore OpenFOAM Programming & Development 12 March 18, 2014 05:22
an error in Calculator's equation immortality OpenFOAM Paraview & paraFoam 11 September 3, 2013 16:18
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
