free surface flow
1 Attachment(s)
hi
At first I apologize for my bad english!!!! I want to simulate a free surface flow in cfx, like a 2D body float on water I modeled a piston wave maker. my two phase flow : water and air in setup : surface tension model 1- none 2- continuous surface force "I chose it" interphase transfer 1- none 2- mixture model 3-free surface "I chose it" is it true!??is there any important problem!? and second question! in solver!! I attach the picture to explain my problem!!?? "solver-pcmpi.exe has stopped working" why!? in both parallel and series run!! if you have any file plz send me plz help me thanks |
The CFX tutorial example "Flow over a bump" shows how to set up a free surface simulation. I recommend you have a look at it, it will answer all your questions you have written here.
hi
ok , I will read that example. thanks |
