Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid
Hello all,
I've been using Ansys 13 CFX to try to determine the forces exerted on a fixed, stationary device that's inserted into a pipe with water flowing through. Up till now, I've been building the (steady-state) simulations as follows:
I've then run the simulation and used the function calculator to work out the force on the fluid-solid interface side that's in the fluid domain, which gives me a force of about 12.5N in the direction of the fluid flow. This I am taking to be the force exerted on the device due to the flow. I've since discovered that rather than defining the device as a solid domain, I can define it as an immersed solid and perform the simulation that way. So, I've rebuilt the model as follows:
I've since run the simulation and used the function calculator to work out the force on the solid domain, but this now gives me a force of 2.5N as opposed to 12.5N I'm not really sure which value is the correct one, or whether I'm using the right simulation method and building the simulations right. Any thoughts? Thanks, |
