[Sponsors] | |||||
Rep Power: 0 ![]() |
Hey,
my name is shauny and this is my first thread here. I investigate the influence of the boundary layer on a centrifugal compressor flow passage. For this is calculated the boundary layer profile (total pressure in stn frame over normalized span) and provided it as a boundary condition at the Inlet. After simulation I wanted a hub to shroud profile at a certain streamwise location. Problem: There are to little sample points in my boundary layer area so that I can't analyse the boundary layer profile. Is there a possibility to get more sample points in this area? I already tried the distribution modes "equal distance" and "mesh density based". I also tried it with a contour plot and manual distribution but CFX Post limits the number of positions after the decimal points of the inserted radius to 7 (I'd like to have up to 11 positions if possible). Polylines also have to little sample points. The only thing which works is a "normal" line but it's difficult to analyse a straight line which do not lie completely in a curved turbosurface. The mesh density is 6*10^-7 [m] at both the hub and the shroud. I hope you can help me. Best regards Shauny |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Can you show a picture of the problem? Are there too few sample points in the boundary you are applying or in the data you are extracting from your simulation?
6e-7[m] means your mesh is less than a micron. Are you modelling a tiny object? Otherwise your mesh sounds too fine. Please show a picture of your mesh as well. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cannot find turbo variable 'Streamwise Location'. | Veronique Pe | CFX | 2 | June 24, 2015 07:32 |
| Dynamic 2d chart | ghost82 | EnSight | 2 | October 24, 2014 18:07 |
| Blade Loading turbo Chart? | prayskyer | CFX | 4 | August 26, 2012 06:30 |
| Gambit turbo problem. | sujan.dasmahapatra | FLUENT | 0 | December 20, 2009 06:21 |
| Chart empty | anna_67 | CFX | 2 | July 27, 2009 08:52 |
