Save data files regularly in steady calculations in CFX 14.5
Like Tree1Likes
  • 1 Post By PeMo
Old   March 6, 2015, 08:32
Default Save data files regularly in steady calculations in CFX 14.5
Gitesh
Gitesh P is on a distinguished road
I am simulating steady-state flow phenomena in ANSYS CFX 14.5. I need to save data files regularly e.g. after every 5000 iterations.
Can anyone tell me how I could do that ?
Thank you in advance.
-Regards, GP
Gitesh P is offline   Reply With Quote
Old   March 6, 2015, 09:15
monkey1 is on a distinguished road
In Pre in the outline tree open output control, go to the 2nd Tab "Backup" and there you can set what data should be saved in which interval.
The only thing is, if I'm not totally wrong...if you set e.g. an Interval of 5.000 Iterations, he will write a .bak file after 5.000 and when he reaches 10.000 he will write a new one, but delete the old .bak...so you will have to save the bak up file in a new folder by hand everytime it is written ...thats the only way I would know for saving the data in a steady state run
monkey1 is offline   Reply With Quote
Old   March 6, 2015, 09:47
Peter
PeMo is on a distinguished road
At the expert Parameters, Tab "I/O Control" you can set the "delete backup files" to false
monkey1 likes this.
PeMo is offline   Reply With Quote
Old   March 6, 2015, 10:40
Opaque will become famous soon enough
In addition to backing up your files for a simulation that long, I would also look at what is wrong with the setup or why does it take that long to converge.
1000's of iterations for a segregated solver are common, for a coupled solver they are not unheard off; however, once you reach 10 000's, something may be off somewhere.
Opaque is offline   Reply With Quote
Old   March 9, 2015, 02:50
Gitesh
Hello again,
Great...it is working
Thank you very much for your suggestions. Now I have what I want.
I have written 5000 iterations as an example. My case converges after about few thousands iterations.
With regards,
GP
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Importing 3D data as CEL into ANSYS CFX 11.0 Dave W. CFX 9 October 19, 2007 08:18
Obtain Geometry Data from a Grid File in CFX 10.0 ARJUN CFX 2 August 17, 2006 07:20
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
How to make data file for matlab from CFX? cfxbeginner CFX 4 October 19, 2002 07:56
