August 27, 2015, 17:28 |
Having problems with Remeshing in CFX
Hebert Cote
Rep Power: 10 |
Help with Remeshing in CFX
Hi. Some time ago I tried to recreate this simulation with remesh (https://www.youtube.com/watch?v=S-p0uau9nGA) in cfx but I have had many problems. If you can help I would appreciate any help is welcome. This is what i have done. Using this tutorial. CFX 14.5 Mesh Morphing Remeshing CFX. the following message continuous images and the tutorial. Last edited by cote2714; August 31, 2015 at 09:57. Reason: images |
August 28, 2015, 04:03 |
Maxim
Rep Power: 12 |
the resolution of your screenshots is too low - we cannot read your settings. What is your exact question? What is your goal? Last edited by -Maxim-; August 28, 2015 at 06:56. |
August 28, 2015, 06:16 |
Rep Power: 143 |
Please post any error messages you are getting. Also post your CCL and as maxim says images with enough resolution to be readable would help.
I can already see your mesh is hopelessly coarse. You will need a zillion more mesh elements than that to get anything to work. |
August 28, 2015, 11:33 |
continued to images and tutorial
Hebert Cote
Rep Power: 10 |
I want to make Remesh like this video (.https://www.youtube.com/watch?v=S-p0uau9nGA). I'm a noob in ANSYS . Thanks for you help.
August 28, 2015, 11:42 |
continuous with images
Hebert Cote
Rep Power: 10 |
August 28, 2015, 12:02 |
tutorial and remesh.out
Hebert Cote
Rep Power: 10 |
Tutorial y remesh.out
https://mega.nz/#!5hlWHDaD!EdifUJR58...uv0L2TBhojY5rw https://mega.nz/#!gtcCjbgI!MOWtfKyqc...HqSLdUozf4dPVc thanks for you help. I want to simulate this case you can see in the video.(https://www.youtube.com/watch?v=S-p0uau9nGA). because this simulation resembles the behavior of a pig in a pipeline. I am studying this for my undergraduate thesis. sorry for my English |
August 28, 2015, 12:37 |
Ccl
Hebert Cote
Rep Power: 10 |
# State file created: 2015/08/31 09:25:30
# CFX-15.0.7 build 2014.04.26-07.00-131803 LIBRARY: CEL: EXPRESSIONS: MeshQuality = minVal(Orthogonality Angle Minimum)@Default Domain Movimiento = 0.1[m]*Time This Run /1[s] RemeshingCond = minVal(Orthogonality Angle Minimum)@Default Domain \ <15[deg] END END MATERIAL GROUP: Air Data Group Description = Ideal gas and constant property air. Constant \ properties are for dry air at STP (0 C, 1 atm) and 25 C, 1 atm. END MATERIAL GROUP: CHT Solids Group Description = Pure solid substances that can be used for conjugate \ heat transfer. END MATERIAL GROUP: Calorically Perfect Ideal Gases Group Description = Ideal gases with constant specific heat capacity. \ Specific heat is evaluated at STP. END MATERIAL GROUP: Constant Property Gases Group Description = Gaseous substances with constant properties. \ Properties are calculated at STP (0C and 1 atm). Can be combined with \ NASA SP-273 materials for combustion modelling. END MATERIAL GROUP: Constant Property Liquids Group Description = Liquid substances with constant properties. END MATERIAL GROUP: Dry Peng Robinson Group Description = Materials with properties specified using the built \ in Peng Robinson equation of state. Suitable for dry real gas modelling. END MATERIAL GROUP: Dry Redlich Kwong Group Description = Materials with properties specified using the built \ in Redlich Kwong equation of state. Suitable for dry real gas modelling. END MATERIAL GROUP: Dry Soave Redlich Kwong Group Description = Materials with properties specified using the built \ in Soave Redlich Kwong equation of state. Suitable for dry real gas \ modelling. END MATERIAL GROUP: Dry Steam Group Description = Materials with properties specified using the IAPWS \ equation of state. Suitable for dry steam modelling. END MATERIAL GROUP: Gas Phase Combustion Group Description = Ideal gas materials which can be use for gas phase \ combustion. Ideal gas specific heat coefficients are specified using \ the NASA SP-273 format. END MATERIAL GROUP: IAPWS IF97 Group Description = Liquid, vapour and binary mixture materials which use \ the IAPWS IF-97 equation of state. Materials are suitable for \ compressible liquids, phase change calculations and dry steam flows. END MATERIAL GROUP: Interphase Mass Transfer Group Description = Materials with reference properties suitable for \ performing either Eulerian or Lagrangian multiphase mass transfer \ problems. Examples include cavitation, evaporation or condensation. END MATERIAL GROUP: Liquid Phase Combustion Group Description = Liquid and homogenous binary mixture materials which \ can be included with Gas Phase Combustion materials if combustion \ modelling also requires phase change (eg: evaporation) for certain \ components. END MATERIAL GROUP: Particle Solids Group Description = Pure solid substances that can be used for particle \ tracking END MATERIAL GROUP: Peng Robinson Dry Hydrocarbons Group Description = Common hydrocarbons which use the Peng Robinson \ equation of state. Suitable for dry real gas models. END MATERIAL GROUP: Peng Robinson Dry Refrigerants Group Description = Common refrigerants which use the Peng Robinson \ equation of state. Suitable for dry real gas models. END MATERIAL GROUP: Peng Robinson Dry Steam Group Description = Water materials which use the Peng Robinson equation \ of state. Suitable for dry steam modelling. END MATERIAL GROUP: Peng Robinson Wet Hydrocarbons Group Description = Common hydrocarbons which use the Peng Robinson \ equation of state. Suitable for condensing real gas models. END MATERIAL GROUP: Peng Robinson Wet Refrigerants Group Description = Common refrigerants which use the Peng Robinson \ equation of state. Suitable for condensing real gas models. END MATERIAL GROUP: Peng Robinson Wet Steam Group Description = Water materials which use the Peng Robinson equation \ of state. Suitable for condensing steam modelling. END MATERIAL GROUP: Real Gas Combustion Group Description = Real gas materials which can be use for gas phase \ combustion. Ideal gas specific heat coefficients are specified using \ the NASA SP-273 format. END MATERIAL GROUP: Redlich Kwong Dry Hydrocarbons Group Description = Common hydrocarbons which use the Redlich Kwong \ equation of state. Suitable for dry real gas models. END MATERIAL GROUP: Redlich Kwong Dry Refrigerants Group Description = Common refrigerants which use the Redlich Kwong \ equation of state. Suitable for dry real gas models. END MATERIAL GROUP: Redlich Kwong Dry Steam Group Description = Water materials which use the Redlich Kwong equation \ of state. Suitable for dry steam modelling. END MATERIAL GROUP: Redlich Kwong Wet Hydrocarbons Group Description = Common hydrocarbons which use the Redlich Kwong \ equation of state. Suitable for condensing real gas models. END MATERIAL GROUP: Redlich Kwong Wet Refrigerants Group Description = Common refrigerants which use the Redlich Kwong \ equation of state. Suitable for condensing real gas models. END MATERIAL GROUP: Redlich Kwong Wet Steam Group Description = Water materials which use the Redlich Kwong equation \ of state. Suitable for condensing steam modelling. END MATERIAL GROUP: Soave Redlich Kwong Dry Hydrocarbons Group Description = Common hydrocarbons which use the Soave Redlich Kwong \ equation of state. Suitable for dry real gas models. END MATERIAL GROUP: Soave Redlich Kwong Dry Refrigerants Group Description = Common refrigerants which use the Soave Redlich Kwong \ equation of state. Suitable for dry real gas models. END MATERIAL GROUP: Soave Redlich Kwong Dry Steam Group Description = Water materials which use the Soave Redlich Kwong \ equation of state. Suitable for dry steam modelling. END MATERIAL GROUP: Soave Redlich Kwong Wet Hydrocarbons Group Description = Common hydrocarbons which use the Soave Redlich Kwong \ equation of state. Suitable for condensing real gas models. END MATERIAL GROUP: Soave Redlich Kwong Wet Refrigerants Group Description = Common refrigerants which use the Soave Redlich Kwong \ equation of state. Suitable for condensing real gas models. END MATERIAL GROUP: Soave Redlich Kwong Wet Steam Group Description = Water materials which use the Soave Redlich Kwong \ equation of state. Suitable for condensing steam modelling. END MATERIAL GROUP: Soot Group Description = Solid substances that can be used when performing \ soot modelling END MATERIAL GROUP: User Group Description = Materials that are defined by the user END MATERIAL GROUP: Water Data Group Description = Liquid and vapour water materials with constant \ properties. Can be combined with NASA SP-273 materials for combustion \ modelling. END MATERIAL GROUP: Wet Peng Robinson Group Description = Materials with properties specified using the built \ in Peng Robinson equation of state. Suitable for wet real gas modelling. END MATERIAL GROUP: Wet Redlich Kwong Group Description = Materials with properties specified using the built \ in Redlich Kwong equation of state. Suitable for wet real gas modelling. END MATERIAL GROUP: Wet Soave Redlich Kwong Group Description = Materials with properties specified using the built \ in Soave Redlich Kwong equation of state. Suitable for wet real gas \ modelling. END MATERIAL GROUP: Wet Steam Group Description = Materials with properties specified using the IAPWS \ equation of state. Suitable for wet steam modelling. END MATERIAL: Air Ideal Gas Material Description = Air Ideal Gas (constant Cp) Material Group = Air Data, Calorically Perfect Ideal Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 28.96 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-2 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END END END MATERIAL: Air at 25 C Material Description = Air at 25 C and 1 atm (dry) Material Group = Air Data, Constant Property Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Density = 1.185 [kg m^-3] Molar Mass = 28.96 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-02 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 0.003356 [K^-1] END END END MATERIAL: Aluminium Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 2702 [kg m^-3] Molar Mass = 26.98 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 9.03E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 237 [W m^-1 K^-1] END END END MATERIAL: Copper Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 8933 [kg m^-3] Molar Mass = 63.55 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 3.85E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 401.0 [W m^-1 K^-1] END END END MATERIAL: Soot Material Group = Soot Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 2000 [kg m^-3] Molar Mass = 12 [kg kmol^-1] Option = Value END REFERENCE STATE: Option = Automatic END ABSORPTION COEFFICIENT: Absorption Coefficient = 0 [m^-1] Option = Value END END END MATERIAL: Steel Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 7854 [kg m^-3] Molar Mass = 55.85 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4.34E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 60.5 [W m^-1 K^-1] END END END MATERIAL: Water Material Description = Water (liquid) Material Group = Water Data, Constant Property Liquids Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 997.0 [kg m^-3] Molar Mass = 18.02 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4181.7 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0.0 [J/kg] Reference Specific Entropy = 0.0 [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.6069 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 2.57E-04 [K^-1] END END END MATERIAL: Water Ideal Gas Material Description = Water Vapour Ideal Gas (100 C and 1 atm) Material Group = Calorically Perfect Ideal Gases, Water Data Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 18.02 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 2080.1 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1.014 [bar] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 100 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 9.4E-06 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 193E-04 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END Last edited by cote2714; August 31, 2015 at 10:21. Reason: ccl |
August 28, 2015, 17:11 |
Rep Power: 143 |
Your images are still too low res to be useful. Also I do not download stuff from unknown links.
As I said, please: * Post readable images * Post any error messages you are getting * Post your CCL (it is just a short test file so can go directly onto the forum) |
August 31, 2015, 10:22 |
CCL continous
#9 |
Hebert Cote
Rep Power: 10 |
Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END END END END FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 5 [s] END TIME STEPS: Option = Timesteps Timesteps = 0.01 [s] END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Fluid Location = B28 BOUNDARY: Caja Boundary Type = WALL Location = Caja BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall Wall Velocity Relative To = Mesh Motion END MESH MOTION: Option = Specified Location LOCATION: Location X Component = xGlobal Location Y Component = yGlobal Location Z Component = zGlobal-Movimiento Option = Cartesian Components END END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Entrada Boundary Type = INLET Location = Entrada BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Mass Flow Rate = 2 [kg s^-1] Option = Mass Flow Rate END MESH MOTION: Option = Stationary END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: Pared Boundary Type = WALL Location = F29.28,F30.28,F39.28,F40.28 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall Wall Velocity Relative To = Mesh Motion END MESH MOTION: Option = Unspecified END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Salida Boundary Type = OUTLET Location = Salida BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Average Static Pressure Pressure Profile Blend = 0.05 Relative Pressure = 0 [psi] END MESH MOTION: Option = Stationary END PRESSURE AVERAGING: Option = Average Over Whole Outlet END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Displacement Relative To = Previous Mesh Option = Regions of Motion Specified MESH MOTION MODEL: Option = Displacement Diffusion MESH STIFFNESS: Option = Increase near Small Volumes Stiffness Model Exponent = 2.0 REFERENCE VOLUME: Option = Mean Control Volume END END END END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Fluid Temperature = 25 [C] Option = Isothermal END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon END TURBULENT WALL FUNCTIONS: Option = Scalable END END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0 [psi] END TURBULENCE INITIAL CONDITIONS: Option = Medium Intensity and Eddy Viscosity Ratio END END END OUTPUT CONTROL: BACKUP RESULTS: Backup Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Timestep Interval Timestep Interval = 50 END END MONITOR OBJECTS: MONITOR BALANCES: Option = Full END MONITOR FORCES: Option = Full END MONITOR PARTICLES: Option = Full END MONITOR POINT: Deplazamiento Z Coord Frame = Coord 0 Expression Value = areaAve(Total Centroid Displacement Z)@Caja Option = Expression END MONITOR POINT: Remesh Coord Frame = Coord 0 Expression Value = minVal(Orthogonality Angle Minimum)@Default Domain \ < 15[deg] Option = Expression END MONITOR POINT: RemeshQuality Coord Frame = Coord 0 Expression Value = minVal(Orthogonality Angle Minimum)@Default Domain Option = Expression END MONITOR RESIDUALS: Option = Full END MONITOR TOTALS: Option = Full END END RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Timestep Interval Timestep Interval = 10 END END END SOLVER CONTROL: Turbulence Numerics = First Order ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 10 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END INTERRUPT CONTROL: INTERRUPT CONDITION: Interrupt Condition 1 Logical Expression = RemeshingCond Option = Logical Expression END END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END EXPERT PARAMETERS: solve energy = f solve fluids = f solve turbulence = f solve wallscale = f END END COMMAND FILE: Version = 15.0 END SIMULATION CONTROL: CONFIGURATION CONTROL: CONFIGURATION: Configuration 1 Flow Name = Flow Analysis 1 ACTIVATION CONTROL: CONTROL CONDITION: Activation Condition 1 Option = Start of Simulation END END REMESH: Remesh 1 Activation Condition List = Interrupt Condition 1 External Command = "C:\Program Files\ANSYS \ Inc\v150\Framework\bin\Win64\runwb2.bat" -B -R "D:\Simulaciones \ Tesistas\PIG\Caja-Tubo\Remesh1\Remesh.wbjn" Location = Assembly Option = User Defined Replacement Mesh File = D:\Simulaciones \ Tesistas\PIG\Caja-Tubo\Remesh1\Remesh1_files\dp0\global\MECH\SYS.msh \ db END END END END |
August 31, 2015, 16:00 |
Ready
#10 | |
Hebert Cote
Rep Power: 10 |
hello, ghorrocks, ready and modify the images and assemble the CCL I hope you can help me and apologize for any inconvenience |
August 31, 2015, 18:17 |
#11 |
Rep Power: 143 |
What error messages are you getting?
September 1, 2015, 18:57 |
I have this error
#12 |
Hebert Cote
Rep Power: 10 |
| ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | REDHDR: locating dataset failed: what=G/NAMEMAP where=EVERY | | | | | | | | | | | +================================================= ===================+ I could say whether the configuration of this setup well for the Remesh or errors can be run or I can give recommendations to achieve realize the Remesh. Please.I appreciate any help you can give me |
February 21, 2017, 02:53 |
#13 |
Ganesh Narayana
Rep Power: 10 |
have you got any solution for this error of yours?? am facing the same here, have been using ICEM CFD Replay file for remeshing
resmeshing.remesh cfx |
[ICEM] Simple pipe meshing - problems with y+ in CFX | Keizers | ANSYS Meshing & Geometry | 23 | January 15, 2015 08:00 |
CFX thermo-fluid 2D simulation problems | maryliz | CFX | 6 | October 31, 2011 23:26 |
CFX -5.7.1 Intermittent Licensing Problems | James Date | CFX | 4 | February 14, 2005 06:22 |
CFX - Parallel Problems | CFX User | CFX | 0 | November 1, 2004 18:12 |
CFX problems no NT? | Michael Bo Hansen | CFX | 0 | September 28, 2000 09:55 |
