error about fsi in CFX and ANSYS
Hi all !i am faced with some problems about fsi by ANSYS and CFX. the problems as follow:
in ANSYS : *** WARNING *** CP = 56.098 TIME= 21:12:55 Element shape checking is currently inactive. Issue SHPP,ON or SHPP,WARN to reactivate, if desired. *** WARNING *** CP = 27324.324 TIME= 02:48:54 Error in getting field convergence info. From process CFX. *** ERROR *** CP = 27324.324 TIME= 02:48:54 Error during get field convergence Write Please send the data leading to this operation to your technical support provider, as this will allow ANSYS, Inc to improve the program. *** FATAL *** CP = 27324.324 TIME= 02:48:54 An error has occurred. SIF_GetNextRequest, returned the error message: Read. ************************************************** ********************** The above error is non-recoverable by ANSYS ANSYS run terminated by the indicated error Current data base saved if possible. ************************************************** ********************** in CFX: ERROR #002100061 has occurred in subroutine SERVE_CLIENTS. | | Message: | | The connection between this CFX process and an external process | | has died unexpectedly. The following error was received: | | External process : ANSYS | | Error experienced : Read | | | | ** This error is fatal: Terminating ANSYS CFX Solver execution ** | | Please review the output, error and log files from both the CFX | | and external processes to determine the cause of the error. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ i want to find reason about it. Will be thankful for help! WANG |
You only show the ansys output:
