April 30, 2015, 08:10 |
Error in saving data
Anthi Gkesouli
Rep Power: 14 |
I am modelling a two phase (air-water) tank.
The model have run "successfully", i.e. the residuals and the flow field is ok, for about 50000 iterations. I have stopped the run about 10 times in order to check the flow field. Suddenly, i.e. the next time stopped the run, the following error appears: The results from this run of the ANSYS CFX Solver have been | | written to | | C:/phd/Tank/Tank_pending_tasks/dp0_CFX_Solution/Fluid | | Flow CFX_007.res | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error removing file | | C:\phd\Tank\Tank_pending_tasks\dp0_CFX_Solution\Fl uid | | Flow CFX_007.dir\mon.old: Permission denied | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Unable to remove working directory: Directory not empty | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. Then, an x is obvious in the the solution in the cfx tree in workbench. Has anybody face this problem? I have tried to save as the run in a diffrent file with another name but the problem still exists. Thanx in advance Anthi |
April 30, 2015, 18:34 |
Rep Power: 143 |
Looks like you have something using the mon.old file and locking it. You should be able to manually delete the temporary directory.
saving transient data for 1 point & 1 variable | REH | CFX | 8 | November 24, 2015 16:09 |
Error while saving the case and data file | Sri | FLUENT | 6 | September 2, 2015 09:55 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Urgent : Saving the plot data to a file | ck1973 | FLUENT | 1 | July 14, 2006 07:44 |
