May 7, 2015, 01:31 |
Linking Problem
Rep Power: 13 |
I have obtained solution of cylinder. Here I used FLUENT udf to identify/visualize the regions of viscous and shock effects. In fluent post processing, I am clearly observing these regions. When I imported same .cas and .dat file to CFX post, am not able to find these regions.. Is it possible to link fluent udf to CFX post? If so then how it is done? Thanks in advance |
May 7, 2015, 02:22 |
Rep Power: 143 |
No, you cannot directly link a Fluent UDF to CFD-Post.
But you can get the UDF to set a simulation variable which you write to the results file. You can view that in CFD-Post. Or you might be able to do the same calculation which is done in the UDF in CFD-Post. |
May 7, 2015, 02:27 |
#3 | |
Rep Power: 13 |
Can you explain little bit more as how it is done? |
May 7, 2015, 18:18 |
Rep Power: 143 |
In fluent, write the UDF result to a user variable. Make sure the user variable is in the output file. Then you can see it in CFD-Post.
May 8, 2015, 01:55 |
#5 | |
Rep Power: 13 |
Thank you
Please lead me |
May 8, 2015, 02:51 |
Rep Power: 143 |
If the results of the UDF are present in the cas and dat files then can't you visualise that?
May 8, 2015, 03:08 |
#7 | |
Rep Power: 13 |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
